exhaust question?
Old April 11th, 2007, 06:38 AM   #1
MoneyMike02GT is on a distinguished road
Send a message via ICQ to MoneyMike02GT
exhaust question?
i have a 2000 mustang gt with o/r x and flowmasters. i want my car to be louder so i have a question. would any of you cut the cats and run straight pipes with no converters all the way back. no converters what so ever. do you know if my car would have the same tone it has now and just be louder or it would it be just some shitty sounding tone? also would this cause an increase in power or just noise?
Old April 11th, 2007, 11:28 AM   #2
02steedagt is on a distinguished road
Send a message via AIM to 02steedagt
dude, if you have an o/r (off road) x-pipe, you don't have any catalytic converters.
if you want louder, get yourself some long tube headers and maybe like a BBK x-pipe and a set of magnapacks to replace those shitty flows.
"America is all about speed. Hot, nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old April 11th, 2007, 07:31 PM   #3
putermech's Avatar
1999 GT Black Coupe
putermech is on a distinguished road
Actually he probably does have them. 1 on each side instead of a pair on each side like in the stock cats. BBK had hi flow convertors for both X and H which match up with there long tube.
BTW you want some sort of back pressure or you will lose horse power and may even not run at all. That's why you find senors on the intake as well as exhaust all talking to the PCM.
H pipe is louder with less horse power and torque. This has to do with the excape of exhaust pulsing threw the pipes during firing. Like water...it takes the path of lease resistes and doesn't want to turn 90 degrees but rather run on by. Where X pipe passes both sides which gives even tone.
For really loud exhaust, the SLP LM1 and for a deeper tone, the LM2.
BBK long tube (ceramic) with X-pipe (MILs) and SLP LM1 (modular) probably be the loudest and legal stang exhaust on the market.
All above for around $1200 and 25-50 hores.
If you don't use converters...then maybe add spark plugs at the end of the pipes with coilpack and switch...that way you can burn a pretty sweet flame on anyone tail gating you in traffic.
youtube.com has tones of videoes. So you can see for self.
5 Speed w/ Trac-control
Old April 11th, 2007, 07:56 PM   #4
he said he had an OFF ROAD x-pipe. that means he does NOT have cats. true about the high flow, he might have that but that's not what he said. and NOT true that the car wont run at all without backpressure and running lower backpressure deosn't exactly make you loose power, you might loose a little low end torque, but your top end will be better.
-oh and if he has a bbk o/r x-pipe, he is NOT LEGAL.
-get the SLP LM 2, the 1's are shit.
Old April 15th, 2007, 10:30 AM   #5
cliffyk's Avatar
cliffyk is just really nicecliffyk is just really nicecliffyk is just really nicecliffyk is just really nice
My '03 GT came to me with an o/r H and Flowmasters--it was so loud that it was embarrasing, as it was advertising something it didn't have. Stock GTs are reasonably quick, but they are not THAT fast.
I'm running a catted X (UPR) now, with Magnaflows and I find it to be just about the right balance between what's being advertised and what can be delivered...
-cliff knight-
My Mustang
2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch
3.73s, 262 rwHP/305 ft.lb.
Flex-fuel: burns gas and rubber...
Old April 16th, 2007, 07:45 PM   #6
Richs96 is on a distinguished road
Kinda off the subject here but were do you get a shifter like the one you have as your picture? Is it a short throw like the tri-ax or just a stock replacement?
96 GT 5 speed
K&N w/Modified stock air box (Chep ass)
Flowmaster cat back
Tri-Ax Short Throw
PI intake to come
Old April 16th, 2007, 08:13 PM   #7
cliffyk's Avatar
It's an MGW, with a custom decorative boot...
-cliff knight-
My Mustang
Old April 17th, 2007, 02:30 AM   #8
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
My bud has 3" MAC exhaust on his '02 GT with an off road x-pipe and it is loud! I can tell when he is on his way over to my house before he even turns down the block (absolutely NO exageration there)...and it sounds pretty freaking bad ass too!
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old April 17th, 2007, 09:00 AM   #9
zkid01 is on a distinguished road
+100 this is one of the loudest ive heard, with a good tone. Pypes is also pretty F* loud.
Work Hard....Play Harder.
Threads Similar to: exhaust question?
Exhaust question 06RedfireGT The Clubhouse 6 September 25th, 2007 11:46 PM
sorry another exhaust question 02MiNeRaLgRaYGT 99-04 2 July 1st, 2007 10:09 AM
exhaust help/ question burin_rubber V6 Mustangs 14 April 15th, 2007 06:34 PM
Exhaust question... D-Brow V6 Mustangs 3 February 7th, 2007 03:44 PM
91 LX exhaust question 9stang1 5.0 Mustangs 2 November 13th, 2006 10:34 PM
