Clutch Cable \ Quadrant Help Needed
Old April 11th, 2007, 11:22 AM   #1
jrhurst's Avatar
jrhurst is on a distinguished road
Send a message via Yahoo to jrhurst
So when i got my stang , it had just had a new clutch and cable , and quadrant installed 6 months before i got it . After having it 4 months , the cable broke at the upper quadrant . It was suppose to be a steeda cable and tripple prong quad . I even called lonestar performance to verify the work and what products was used . After talking to a couple shops here in DFW area , i was told that the stock cable was best so i ordered one . My biggest concern after taking the broke cable off is how do you adjust the stock cable ? The steeda one had a threaded piece on the fork with 2 nuts for adjustment , but from the pics of the stock one , i dont see any similar adjustment methods . Can any one offer any help in this area please ? Thanks
http://www.myspace.com/jryotas
Old April 11th, 2007, 11:36 AM   #2
mdvaldosta's Avatar
11.47@120.58
The stock one is meant to be adjusted via the stock plastic clutch quadrant (by pulling up on the clutch pedal). If you're using an aftermarket quadrant and the stock clutch, then you'd need to get a firewall adjuster (something like this or this). You'll have to cut part of the end (where it goes to the firewall) off your stock cable but it's pretty easy.
Old April 11th, 2007, 10:08 PM   #3
jrhurst's Avatar
well , i got the stock cable on and i got lucky that the middle fork on the upper quadrant was almost perfect for the stock length . Nothing a rubber spacer didnt fix . I guess i will get a firewall adjuster soon though just in case . Any suggestions on which one to get ?
Old April 12th, 2007, 12:00 AM   #4
ujslost's Avatar
any of them just make sure it has a locking mechanism
i had a upr one that had a little click lock. i liked it
Old April 12th, 2007, 03:02 AM   #5
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I'm using the Maximum Motorsports quadrant and adjuster, and it works great. The only problem I had with them is I had to file/sand down the bushing they gave me so it would fit in the adjuster.
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Threads Similar to: Clutch Cable \ Quadrant Help Needed
Steeda Clutch Adjustment Quadrant, Cable, Firewall Adjuster. fallstar01 Parts 4 August 26th, 2010 02:51 PM
88 5.0 LX Clutch Quadrant 88LX5.0 5.0 Mustangs 7 August 19th, 2010 04:42 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 03:33 PM
Clutch Quadrant RC02GT 99-04 1 March 8th, 2007 04:46 AM
clutch quadrant acg 5.0 Mustangs 4 January 25th, 2007 11:50 PM
