3.73 gears
how fast should a stock 00gt go with 3.73 gears in 5th gear at 2000rpm..
i no tht the 87-93 5.0 go 60mph at 2000rpm in 5th gear with a 3.73
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip |
Proud American
Timber has put up calculators on this a lot! Just search around a little!
64 per my calculations...
-cliff knight- My Mustang 2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch 3.73s, 262 rwHP/305 ft.lb. Flex-fuel: burns gas and rubber... |
Y2K GT
13.3@103
i have 3.90s in my car and i only run 64/65 at 2100rpm in 5th
i have 3.73's, and at 2000 rpm's, im just under 70 mph
"America is all about speed. Hot, nasty, bad ass speed." Eleanor Roosevelt, 1936
i have 4.10s and 56 at 2000
2001 Mustang GT Auto Cold Air Intake BBK 75mm TB BBK Plenum BBK X PIPE no Cats MagnaFlow Cat Back 410's gears New upper and lower rear control arms. |
Wow, they make a big diff, I have stock 3.27's and at 60mph i'm at about 1600rpm.
4.10's soon, can't wait\ |
yes make a big diff, and did cut into the gas also, but not to much, was getting like 285 per tank, now getting 265. but 4.10s are so much fun, you can feel the push when you get on it
Threads Similar to: 3.73 gears
| 3.73 gears or 4.10 gears? I need to get away from the 3.31's | 07torchgt | 2005 - 2010 | 91 | November 11th, 2007 01:25 AM |
| T-Loc or Gears? | Nick_Rapitis | V6 Mustangs | 24 | May 13th, 2007 05:18 PM |
| Gears | Sh0gun! | V6 Mustangs | 12 | April 3rd, 2007 02:26 PM |
| gears | 4.6gtmarine | 99-04 | 7 | April 3rd, 2007 11:23 AM |
| Gears? | gregkelley | 5.0 Mustangs | 4 | March 25th, 2007 05:34 PM |
