head unit wiring question
Old February 20th, 2011, 04:24 PM   #1
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
Well, the question isn't exactly about the headunit. I bought a special iPod adaptor for the head unit(damn company makes you buy their special one like apple or some s***). Anyways, this seperate adapter that plugs into the headunit requires its own 12v power supply. My question is where should I tap into to get that power? Would splicing into the power supply for the actual head unit be safe? Any help is appreciated, my good amigos.
EDIT: It's an Eclipse CD3100 with an iPC-106 adapter if anyone else has this
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Old February 20th, 2011, 06:40 PM   #2
UnSungHero48's Avatar
1998 3.8L v6 Mustang
Dunno (I dont push her)
UnSungHero48 is on a distinguished road
If course a direct freed would be better, but then again the unit would constantly remain on unless you wired an independent switch for it as well. If you haven't spliced ur head units supply wire already with something else I would say it's fine. Saying it needs it's own 12v power supply is alot different then actually drawing that much at a given time.
If you want to be really safe add the draw that both your iPod unit and your hu need to run and add them together sincethey wud b running in parallel then look into whether or not the current wire will support that much draw. Primary goal is to not to overload the wire. Personally I'm assuming it's a 16 gauge wire that powers your hu. So I'm thinking you should be fine, by it is worth checking into.
UnSungHero48
CAI, Pypes Dual Exhaust, Sony Xplod deck w/4 150watt Speakers & 12" Shallow Sub (Pioneer), custom interior lighting, crystal clear fogs w/custom relay, crystal clear headlights, stripe kit and Gold Trim w/billet grille inserts.
Old February 20th, 2011, 06:59 PM   #3
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Looking over the instructions for the ipod adaptor (which doesn't have a ON/OFF switch or anything) says it want s a permanent 12v supply. The head unit has 2 power inputs, one for key on input(when key is on ACC, red wire) and one that has power constantly(B+, yellow wire). I'm thinking this adapter will want the yellow wire.
Old February 20th, 2011, 11:10 PM   #4
me to, like i said, just dont over draw the wire. otherwise i'd say your golden
UnSungHero48
Old February 21st, 2011, 11:40 PM   #5
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Well after some more googling I found that, since there is no memory or anything on the adapter, you can hook it up to the red, which I did. that way if I leave the ipod plugged in it wont drain the battery. and the wire says 300V on it, does that mean volts? I looked for an amp rating or gauge, closest I could find was it said 18AWG or 18AW(something) idk what that means. 2 hours of straight use and no funny smells so hopefully Im not overloading the wire.
Old February 22nd, 2011, 04:15 PM   #6
If t hasnt overloaded already then it won't. Good work thumbie!
UnSungHero48
Old February 22nd, 2011, 07:51 PM   #7
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
haha thanks, now if only it would let me rep you again...
Old February 23rd, 2011, 01:12 AM   #8
lol its all good, i do alot of wiring stuff. kinda surprised im not going into electricl now that i think about it. but o well, at least im putting all that i learned in my PHYs101 class to good use!
UnSungHero48
Old February 23rd, 2011, 02:16 PM   #9
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Nice! I'm actually in an electric circuits class right now. Problem is, all they teach you is how to find current and voltage and stuff, nothing about different kinds of wires and real world stuff like that.
Threads Similar to: head unit wiring question
head unit question kenpachifknpwns Audio/Video 8 August 3rd, 2010 01:36 PM
Head unit question pear0119 2005 - 2010 8 August 6th, 2009 02:39 PM
2008 Mustang Stock Head Unit Wiring help mike4realz Audio/Video 5 October 5th, 2008 05:33 PM
Head unit install and question bandity2k00 Audio/Video 3 September 11th, 2008 02:13 AM
'04 wiring head unit diagram johnbarberr V6 Mustangs 0 May 23rd, 2007 08:25 PM
