i need ideas of what the problem might be
Old February 20th, 2011, 05:36 PM   #1
01 mustang gt
13.98@100
1TITAN is on a distinguished road
the car : 01 mustang gt
set up: 03 f150 block and heads
long tube headers, catless h-pipe, side exhaust
cold air intake, 70mm throttle body
(thats it for engine stuff)
the car ran at the track last year in february with outside temp at about 70 degrees it ran a 13.98 @ 99mph
the problem: the car slowly is moving losing power some how and some where and i cant figure out why. it doesnt run funny at all which is whats so odd, it doesnt hesitate, stumble, bog down...... its has a loss of low end power to the point that it wont spin the tires from a stand still, and the top end doesnt really seem that much better
the last time i went to the track was this past november and the conditions were almost identical to the february run with temp. at about 75...... this car ran a 15.67 @ 88mph
highly embarrassing even more confusing because im not sure where to start or what i might be missing.
any help would be greatly appreciated
destroy in the turns, then obliterate on the straightaway
01 GT
4.6/20 over
cold air intake/70 mm throttle body
mac longtube headers/custome H pipe/moroso spiral mufflers to side exhaust
computer tune
race seats / 5 point harness
Old February 21st, 2011, 12:55 AM   #2
2003 mustang GT
03gtmonster is on a distinguished road
says in your sig "computer tune" if you did that between your two track visits maybe a bad tune could be the problem. you could call the guys at Next Level Performance and im sure they could assist you for a good price, or to just give you some help/ideas. good luck
MAC long tubes, MAC O/R midpipe,american thunder catback, MAC cold air intake, MAC UD pulleys, C&L plenum, 75mm roush TB, TCI torque conv, zex wet 100 shot, dyno tune, H&R SS springs, and 4.10's.
Old February 21st, 2011, 07:48 PM   #3
01 mustang gt
13.98@100
the computer tune has remained the same for about 2 years >:/
01 GT
4.6/20 over
computer tune
Old February 23rd, 2011, 11:37 PM   #4
jk_aktion's Avatar
jk_aktion will become famous soon enough
where at in orlando? don't mind if i come check it out would you.?
Old March 3rd, 2011, 12:05 AM   #5
01 mustang gt
13.98@100
im in wintergarden (west orlando)
i checked to see if any codes where thrown and what i found was that
b1220 (Fuel Tank Pressure Sensor Circuit Open)
i understand that the fuel system isnt there then the car will run like shit but..... what exactly does this code mean is happening to the car?
if any one knows
01 GT
4.6/20 over
computer tune
Old March 4th, 2011, 06:50 PM   #6
01 mustang gt
13.98@100
fuel pressure regulator?...
if it was bad would the car still run?
01 GT
4.6/20 over
computer tune
Old March 6th, 2011, 04:56 PM   #7
86er's Avatar
you dont have a fuel pressure regulator, fuel pressure is done by pulse width modulation of the fuel pump by the driver. More pressure, more voltage, less pressure, less voltage.
Id start with the simple stuff, clean/replace the air filter. New fuel filter, new plugs. Basic maintance is grossly over looked by most on this board.
Just a truck
Old March 6th, 2011, 11:00 PM   #8
01 mustang gt
13.98@100
thats a good point,
im gonna feel like a jackass if its somethin like that
01 GT
4.6/20 over
computer tune
Old March 7th, 2011, 04:42 AM   #9
Trentimus's Avatar
2003 Cobra
Trentimus is on a distinguished road
Originally Posted by 1TITAN View Post
thats a good point,
It's okay to feel like a jackass if it is because that's a cheap fix
Old April 4th, 2011, 01:57 AM   #10
01 mustang gt
13.98@100
its taken me a while but i put a fuel pressure gauge to the car and at an idle it only makes
25psi (its supposed to be between 40-70)
so this information coupled with the code that i read from the ecu, does any body think with out a reasonable doubt that it has something to do with the FRPS?
01 GT
4.6/20 over
computer tune
Old April 4th, 2011, 04:44 PM   #11
01 mustang gt
13.98@100
i just read my own powt and realized ive been talking about the wrong sensor...
the code i threw was in regards to the FUEL TANK PRESSURE SENSOR and not the frps
so time to ask again, does any one know the symptoms of a fail FUEL TANK PRESSURE SENSOR?
how hard is it to replace?
is this somehow the reason for my cars questionable performance?
01 GT
4.6/20 over
computer tune
Threads Similar to: i need ideas of what the problem might be
misfire problem, probelms, probably a problem? rewadferger 96-98 5 September 13th, 2010 12:17 PM
just solved my evap problem now a more serious problem arises I NEED HELP please sj408 96-98 5 July 16th, 2010 08:12 PM
Transmission problem??? need help diagnosing the problem... Tmac3320 99-04 19 April 13th, 2009 12:58 AM
on going problem and ideas please help ricvpi 96-98 6 February 27th, 2009 04:29 PM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
