Ram air or cold air?
Old April 24th, 2007, 10:37 AM   #1
shadow98gt's Avatar
1998 Mustang GT
shadow98gt is on a distinguished road
I've been looking into getting a ram air kit for my 98 gt, but im not sure if i should go cold air or ram air!?
Old April 24th, 2007, 10:40 AM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
cia will net more HP but you won't be able to drive through any puddles.
Old April 24th, 2007, 01:23 PM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Regarding puddles, it depends on the cold-air setup.
I'd say go CAI over ram-air, CAIs *always* make more power, whereas ram air setups only make power at speed (and it's not much power at normal highway speeds). CAIs are cheaper, and I've yet to see a ram-air that didn't make the air go through a couple 180s to get to your airbox.
O o
/¯/______________________
\_\
Old April 24th, 2007, 02:29 PM   #4
02steedagt is on a distinguished road
Send a message via AIM to 02steedagt
rev i think you've got it backwards..... the cold air bends into the fender well and the ram air stays in the engine bay.
"America is all about speed. Hot, nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old April 24th, 2007, 02:53 PM   #5
shadow98gt's Avatar
1998 Mustang GT
k thanks for the help i'll look into some cai's...
Quit smilin your drivin a camaro!!
Mods:
Currently going through a sex-change. Going in Michael jackson coming out Kimbo Slice!!
MM Cobra Member # 87
Old April 24th, 2007, 11:09 PM   #6
what do you mean by ram air? I'm thinking of the Cervini's setup with the two hood scoops.
O o
\_\
Old April 25th, 2007, 12:18 AM   #7
shadow98gt's Avatar
1998 Mustang GT
march performance puts out a cheap ram air kit the hooks up to your existing intak and it goes under the car and air gets forced in
Mods:
Old April 25th, 2007, 07:48 AM   #8
zkid01 is on a distinguished road
No no when we are talking about a ram air intake.. its a short version of the CAI.. it usually has the filter sitting in the stock location and has new tubing.. Makes some good power.. not as much as some cold air intakes, but a good upgrade.
Your thinking of ram air, like the mach 1 stock setup with a scoop on the hood.. its a diff thing. And I would think that the march kit would get you a little more air but you can build that yourself for like $5 to buy some ducting. Or you would have better luck getting a ram air intake and takeing off your pass side headlight when at the track to get more air forced into the intake.
Work Hard....Play Harder.
Old April 25th, 2007, 10:08 AM   #9
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
ram air
vs cold air
Old April 25th, 2007, 11:47 AM   #10
Originally Posted by zkid01
No no when we are talking about a ram air intake...
Your thinking of ram air, ... its a diff thing.
Someone may be selling that under the product name of "ram air" but a shortened CAI is *NOT* ram air. It's called RAM air because it RAMS the air into your motor. Talking about replacing the intake tubing is entirely different,
At least you can understand why I might be confused on the issue...
If we're talking about a true CAI vs. a Conical filter, I went with the conical because it was a hell of a lot easier to install, and it's a lot easier to just look in, see if my filter needs to be cleaned, and if it does, take it out and clean it. I don't have to go digging into my fender liner anytime I want to check my air filter, plus, the CAIs I was looking at were about $100 more. On top of that, the K&N setup has a heat shield, so most of the air is coming from the fenderwell anyway.
If you're trying to squeeze out every last horsepower, CAI is the only way to go.
O o
\_\
Old April 25th, 2007, 01:03 PM   #11
shadow98gt's Avatar
1998 Mustang GT
ok ok here is a picture of the ram air set up... its not the short ram kit your thinking of... its by march performance!
Mods:
Old April 25th, 2007, 06:12 PM   #12
jagstang96's Avatar
jagstang96 is on a distinguished road
I have the march ram air kit and love it , ive also used the jlt intake and really liked it to . As far as the sucking up water issue I bought a sponge and cut it to fit painted it black no problem at all .
Threads Similar to: Ram air or cold air?
Cold Air chickenbot 5.0 Mustangs 42 November 13th, 2007 03:44 PM
Ram Air or Cold Air TheMatt06 5.0 Mustangs 2 May 18th, 2007 10:48 PM
cold flames_blue V6 Mustangs 20 April 24th, 2007 02:10 PM
BBK Cold Air 95 On A 90? redwhiteanblue 5.0 Mustangs 3 November 9th, 2006 12:17 AM
Cold Air Kit RottManK9 99-04 24 October 29th, 2006 09:23 AM
