Nobody Can Change out My Tires! - Page 2
Old March 21st, 2011, 05:32 PM   #21
justin146's Avatar
1999 Cobra Vert
justin146 is on a distinguished road
Originally Posted by NastyStang113 View Post
And sadly most techs at the dealer don't give a shit about getting it as perfect as possible.
I agree, but these guys are the exception. Just across town at the Goodyear dealer it would have cost me $100 to get them mounted, but I dont trust those guys at all.
2001 BMW 540i M-sport 6 speed, staggered type 66 wheels, m5 shifter, muffler delete. Replaced my Cobra as my track car...
Old March 22nd, 2011, 06:44 AM   #22
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about
i always watch whenever someone else is working on my car. Its like leaving your kid at the mall with a stranger... Makes you worry lol
i usually wave first, but if the guy is sexy and i'm drunk, i might lift up my shirt and flash him as well.
MM Cobra Club Member #61
Old March 22nd, 2011, 10:03 AM   #23
justin146's Avatar
1999 Cobra Vert
I never like to leave my vehicle unattended. If i had to leave my turbo Exporer anywhere I would set the rev limiter to 2k.
Old March 29th, 2011, 01:09 PM   #24
stang 2002's Avatar
2002 mustang gt
stang 2002 is on a distinguished road
I used to change tires 20 ys ago and if they cant get them off your wheel,they have problems. The worst I have ever had to do was cut a tire at the beed if it was that stuck. That was because they drove on the tire when they had a blow out and the wheel got hot. You dont have beed locks on the wheels do ya?
Old March 30th, 2011, 11:06 AM   #25
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
no beed locks, everyone said the tires were just to wide for their presses. I call it lazy
Old March 30th, 2011, 10:36 PM   #26
Supersized Salami Swallower
Kohrs93's Avatar
00 GT
14.043@99.03
Kohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to behold
I work in a shop that only does suspension/brakes and general maintenance. I'm one of the ones doing general maintenance. I understand how much of a bitch getting low profile tires off can be, even if they're not that low profile. On our machines, we have to break the bead, then we bring an arm up to the wheel that has a special fitting on the end of it. Then we use a steel arm to pull the tire up over the fitting, then we push the pedal and the machines spins the tire off. Yesterday i put 2 new tires on a mitsubishi dimante. I was literally hanging off the steal arm trying to get the tire up over the special fitting to take it off. That's how hard some of those low profile tires can be (I'm 6' 225 lbs)
So yes i understand how hard it can be, but those prices are ridiculously exspensive.
Black Stang Crew #Coorslight
Originally Posted by Nameless View Post
It is big...but not as big as this pic makes it appear.
Originally Posted by Dennis View Post
yea now all i need is the time to clean it and lube it and fire it.
BONER CREW EMPLOYEE #3 - RECEIVING DEPARTMENT
Old April 1st, 2011, 05:55 PM   #27
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
Am I the only one who dismounts and mounts all of his own tires? It only takes a couple minutes each and I've never had a problem. Nothing breaks a bead better than a 4X4 chunk of wood and a 7,000 lb truck.
A small shop near me has a road force balancer and charges $2.50 per wheel for the balancing after that.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old April 1st, 2011, 06:59 PM   #28
justin146's Avatar
1999 Cobra Vert
Very likely.
Old April 1st, 2011, 08:37 PM   #29
All Homo All The Time
Nightmare69's Avatar
2003 Mustang GT
Whatever you run plus 5 seconds
Nightmare69 will become famous soon enoughNightmare69 will become famous soon enough
Ive done it with a bottle jack and a tractor. I wouldn't want to try it on these low profile tires cause you could F up your wheel.
BLACK STANG CREW MEMBER #30
Old April 1st, 2011, 08:50 PM   #30
Low profiles are definitely more difficult but I've never had a real problem. As long as your dismounting tools aren't metal on the outside and you only touch the tire to break the bead you shouldn't damage anything.
Threads Similar to: Nobody Can Change out My Tires!
Questions About Tires/ buy rims and tires acomeaux33 V6 Mustangs 0 February 19th, 2010 12:44 AM
which to change... tires smaller or gears shorter? 2006greyGT 2005 - 2010 19 July 16th, 2009 09:58 AM
Nankang Tires? Republic tires? Mr.Chips V6 Mustangs 1 January 19th, 2007 05:33 PM
