Changed plugs, now idling rough
Old March 20th, 2011, 11:47 PM   #1
MD_GT '00 is on a distinguished road
Ok, so I decided to change out my plugs today on my 2000 Mustang GT. Got the OEM motorcraft platinum plugs, to replace my old worn plugs. I replaced them one by one, being careful to blow all dirt out of the way with compressed air, anti-seizing the new plugs, and used dielectric grease on the boot spring connector. I slightly adjusted the gaps on the first 2 to fit the recommended .054, but the other 6 were okay.
In trying to get to the plugs I removed the fuel rail by accident, it sprayed, and I reinstalled, nothing is leaking from this now. One fuel injector that came out of is seating was quite dirty though.
I started the car up and it has a rough idle, with a light pop about once a second. If i rev it up, the car will rev to about 3500 RPM then break. I checked all connectors, and everything is seated properly. There is no check engine light being thrown, but something is definitely not right.
If anyone has any constructive ideas I would greatly appreciate it. I've checked around on forums, and I've seen multiple people have this problem, but no real constructive advice.
Old March 25th, 2011, 09:37 AM   #2
BigBallsMcLongCox is on a distinguished road
I have had the same problem before. Go back a check all your coil packs. Or while the engine is running start pulling the connectors off of each coil pak one at a time as you do you will hear the motor miss and change sound when that happens you know that coil is working plug back in and go to the next if you unplug one and the motor don't change sound you know that is the one that is giving the problem.I always keep extra coils if any kind of moisture gets to the plug it will miss fire hope this helps or you could have a bad boot also.
Threads Similar to: Changed plugs, now idling rough
Changed plugs, now idling rough MD_GT '00 General Tech 1 March 21st, 2011 04:14 AM
87 LX Rough Idling/Stalling Out W4yo 2.3 Mustangs 18 August 13th, 2010 03:52 PM
Idling rough D-Brow V6 Mustangs 11 April 25th, 2010 01:01 AM
Rough Idling jmscobra V6 Mustangs 15 May 2nd, 2009 01:35 AM
rough idling problem VSR13 V6 Mustangs 2 April 17th, 2009 06:15 PM
