has anyone put a Cleveland 351 into an SN95?
I'm interested in rebuilding an engine, and I like the 94-98 body style.
Is it possible to fit the engine into the bay without major modification? Also is it possible to hook up a modern transmission to and older carburated engine? |
Proud American
Yeah! You will need a 94-95 GT crossmember and it should just fit right in there! And I think you can run a modern tranny with the carbs, because arent they based off of vaccum?
Well I've seen T5 conversion kits for first gens. I wonder if they have one for the T56
Thanks for the quick reply btw. I think this could b a cool project as my grandfather worked at Ford (Cleveland) when the 351s were in production and he would be my main source of help |
Proud American
The clevelands are getting harder and harder to come by nowa days because of the short run time! And I bet you could get a T-56 to work with a pushrod! I dont see why not!
the windsor is a better choice and will fit a whole lot easier thana cleveland engine will
hows the power comparison between the two? Also are all the Winsor 351s the same? Tey used those in F150s and Broncos right?
Priest of the Car Gods
My understanding is that the real advantage to the Cleveland was the heads. Absolutely fantastic flow... for the time. Nowadays, you could do a Windsor for cheaper, and get aftermarket heads that flow just as well, if not better. The other thing you could look into is a "Clevor" motor, it's some combination of Windsor and Cleveland parts, I know they're good some ungodly amount of power, the latest Car Craft has one you can buy as a kit (to the tune of $10K) that assembled, is a 427 stroker that makes 700hp on pump gas.
http://mmeracing.com/mmeracing/CrateEngines.asp
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
when i blow my motor, we are planning a 427 windsor with afr heads and some otehr goodies. should be good for over 600 hp all motor, with some 11.5:1 comression
#9 | |
Look Ma! My First Post!
ne body done this swap (cleveland into sn95) yet? Last edited by mustang351sn95; December 27th, 2009 at 11:51 PM. Reason: added currrent car info |
I am sure someone has already done it you should be able to find it on goole quick but it wouldnt be a bad idea
![]() Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne http://www.youtube.com/user/MysticCobra04 |
Threads Similar to: has anyone put a Cleveland 351 into an SN95?
| 351 Windsor or Cleveland | Newtgadget | 5.0 Mustangs | 23 | November 6th, 2007 05:57 PM |
| 1970 351 cleveland | mattsstang | Classic Mustangs | 8 | January 19th, 2007 11:54 PM |
| 351 cleveland | ih8chevy | 5.0 Mustangs | 15 | December 8th, 2006 04:26 PM |
| Cleveland Heads On A 5.0 | 81 Merc. Capri | 5.0 Mustangs | 4 | October 22nd, 2006 07:47 PM |
