Port & Polishing worth the Money
what are the power gains with p&p 4.6 2v haeds w/Turbo?
What are the pro's and con's Thx |
1990 GT
here is a graph comparing a bolt on gt, then a procharged gt and then my gt with all the bolt ons heads and cams and procharger. should be similar with a turbo set up try this link and let me know if it works http://www.pro-dyno.net/gallery/album23/blo_blo_blow
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
Thank you for the info. i did some calling around and decided to go for it.
1990 GT
it is definitely worth it. you will be glad you did it.
Depends on who does the work......
#6 | |
it can hurt ya if someone dont know wtf they are doing
1986 Mustang GT t-top time piece! |
Anyone can cut, grind and shine up a port. Only someone that knows what they are doing can actually make that port flow and make horsepower.
#8 | |
Proud American
What does a flow bench do? I tryed to port one of my goped cylinders, but I runied it! It was a motor that didnt run anyway! I just wanted to try!
a flow bench is a tool used to see how much cfm the ports will flow. usually substituting water for air since the heads aren't on a motor
Proud American
that is cool! I figured it was something like that, but the name is kinda wierd for it!
#14 | |
i'm doing mine myself. i'm about half way done. this is my first time doing it also. I'll post up some pics when i'm finished and the flow chart
Yeah you need to be extremely careful porting and plishing heads yourself as one cylinder can outflow another and ruin the heads
Threads Similar to: Port & Polishing worth the Money
| Is boring .30 over worth the money | wolverine8490 | 5.0 Mustangs | 27 | November 6th, 2007 05:54 PM |
| worth the money | greyauto02 | V6 Mustangs | 17 | October 9th, 2007 02:47 AM |
| Is it worth the money? | whtpny | General Tech | 12 | March 11th, 2007 11:26 AM |
| Port and Polishing Stock Heads | vipereater86 | 5.0 Mustangs | 5 | October 23rd, 2006 08:55 PM |
| Is this worth the money? | 00SoSlow | V6 Mustangs | 4 | August 4th, 2006 04:12 PM |
