1997 Mustang GT
Need to test injectors without installing them
I just got a set of 24lb injectors from my neighbor. I tested the resistance of them and they were all 14.3 ohms. Is there a way to clean them without having them installed? I just wanna make sure theyre clean and ok before I put them on because theyve been sitting in a bag for a few years. The seals arent cracked or anything but I still might get new seals for them
![]() PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune. |
might as well get new seals just for peace of mind ya know??? also if i remember correctly you can soak injectors in gas to clean em out. might wanna verify that with someone first though
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
![]() iTrader: 1 reviews
i dont know if it were smart or not but i cleaned mine with a very fine brush and ether...they have been working wonderfull, and were full or thick grease from my hand when i took them out of the other engine..
1997 Mustang GT
Theyre clean on the outside. I wanna see if I can flush them out or clean them on the inside somehow before I install them.
Authorized Vendor
![]() Join Date: Sep 2008
We usually send injectors in unknown condition to Witch Hunter Performance; he cleans and flow tests them at a fairly reasonable price.
WitchHunter Performance - Injector Cleaning & Flow Testing Services |
Threads Similar to: Need to test injectors without installing them
| How do you test injectors? | Kohrs93 | 99-04 | 5 | May 30th, 2011 08:36 PM |
| drake injectors Versus the seimens deka injectors?? | Barricade | 2005 - 2010 | 2 | May 18th, 2011 03:13 PM |
| Going to test and tune at MIR to test out the mods. | navyman8903 | 2005 - 2010 | 70 | July 5th, 2009 02:09 PM |
| ? on installing larger fuel injectors. | mantis3567 | 99-04 | 11 | October 31st, 2008 08:54 PM |
