is the steel putty the way to go?
Old June 26th, 2011, 12:02 AM   #1
1996 Mustang gt
96red&blackstang is on a distinguished road
so i have a problem; my thermostat bolt broke on to the head. The only way i was able to take it off is by drilling the bolt out. The only problem is now the hole is bigger than the screw, so i added the stuff that hardens like steel and threaded it, but it dont seem to work or dry. any ideas what i can do to fix this, i heard of rewelding the hole and threading it again. that is the last thing i want to do because i want to take my motor to the machine shop in two months, so i need something temporary that would hold.
Old June 26th, 2011, 08:59 AM   #2
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
have you thought about just tapping the hole for a larger bolt?
also next time try heating up the bolt and using some perafin wax to get it to release. usually works like a champ.
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
http://www.moddedmustangs.com/forums...build-bob.html
Old June 26th, 2011, 06:02 PM   #3
1996 Mustang gt
i cant put bigger bolt through the manifold and i wanted to do that, but i didnt want to put heat on it with using a torch in fear of warping the aluminum heads
Old June 26th, 2011, 06:44 PM   #4
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
Helicoil
Old June 27th, 2011, 01:33 AM   #5
1996 Mustang gt
I've heard of that, but don't know how it works.
Old June 27th, 2011, 08:26 AM   #6
Moderator
2003 Grand Cherokee
You drill the hole out to the proper size, insert heicoil (basically a threaded insert), and then insert bolt. Google will help you out and so will the instructions that come with them.
Old June 28th, 2011, 02:06 AM   #7
1996 Mustang gt
thanks
Threads Similar to: is the steel putty the way to go?
is the steel putty the way to go? 96red&blackstang 96-98 13 June 28th, 2011 11:45 AM
Moto STEEL Polished Stainless Steel Headers and H-Pipe RX Bandit 2005 - 2010 6 October 5th, 2009 06:23 PM
Mighty Fu&@$1n Putty TheUNZippee! The Clubhouse 17 June 12th, 2009 09:29 PM
Billett steel or forged steel flywheel? weems The Clubhouse 8 April 13th, 2009 03:21 PM
Homemade silly putty..... JBIGBOOTSY The Clubhouse 24 November 4th, 2007 05:10 PM
