What are the best mods for better handling? - Page 2
Old July 24th, 2011, 10:30 PM   #21
sonicx's Avatar
sonicx will become famous soon enoughsonicx will become famous soon enough
iTrader: 8 reviews
PHB = Pan-Hard bar
TA = Torque Arm
^ Who knows some good brands?
^ Froms those brands where is the best place to purchase them at?
Thanks
Old July 24th, 2011, 11:19 PM   #22
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Hit up MM for all your suspension needs
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old July 25th, 2011, 01:45 AM   #23
sonicx's Avatar
iTrader: 8 reviews
Can the PHB clear MAGNAFLOW magnapacks?
And also... can one just get the TA? (what the difficulty w/ the install if any?)
Thanks
Old July 25th, 2011, 04:08 AM   #24
Hardon Enflooziast
98FireyGT!'s Avatar
'94 GT Vert
Havn't tried...
98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light
Send a message via MSN to 98FireyGT!
Originally Posted by V8ornothing View Post
As the title says what are the best mods for better handling? I already have subframe connectors. So list away.
Cobra IRS
Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP
Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines,
Old July 25th, 2011, 08:28 AM   #25
Abyssinian of AX
'02 Saleen
19.34@42.259
^ Depending on the level of "better handling" one wants to achieve... not necessarily
sonicx... Installing a TA by itself would be of no advantage at all Installing a PHB by itself would help a lot Installing BOTH a PHB and TA would help TREMENDOUS, as this would allow the complete removal of the UCA's.
Jazzer
Old July 25th, 2011, 10:49 AM   #26
sonicx's Avatar
iTrader: 8 reviews
Jazzer
SWEET man now i'd like know please,
Thanks
Old July 25th, 2011, 10:53 AM   #27
Abyssinian of AX
'02 Saleen
19.34@42.259
I cannot tell you this
Even MM has what exhausts their stuff clears/does not clear and is not always right. You can contact MM, but would expect to have some clearance issues in which to address.
Jazzer
Old July 25th, 2011, 11:16 AM   #28
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Okay, so here's the short version, in order, of what you need to address to make a fox-chassis Mustang handle.
0) Maintenance
1) Tires
2) Shocks
3) Chassis bracing
4) Geometry
5) Spring rates
0 is obvious, fix anything that's broken before modifying anything that isn't.
1 really depends on application. If you don't need an allseason, I recommend the Dunlop Direzza Star Spec. If you do, I recommend the Kumho ECSTA ASX.
2 really depends on budget and if you want (and know what to do with) adjustables. I highly recommend Bilsteins, for an adustable it's Koni or GTFO. If you can't afford either of those, the Tokico Blue is decent, though you'll lose some ride quality over the Bilstein.
3 you're already good on, as you have SFCs. If you had a 'vert, I recommend an STB, but you don't, so I don't.
4 is where it starts to get interesting (read expensive). In the back, you need to decide if you want the best handling you can get, or if you're willing to work within the craptastic geometry of the stock 4-link (at a *significant* cost savings). The PhB/TA combo has been covered, and is my recommendation. Another option is the Cobra IRS swap, but you still have to mod it to get it right (if you go this route, talk to Full Tilt Boogie Racing). Up front, at the VERY least, you will need CC plates, as the stock setup is sorely lacking in both negative camber and caster. If you're baller, an SLA swap up front is the ultimate way to go. One thing I want to say here is that coil-overs DO NOT IMPROVE GEOMETRY. Coil-overs will NOT improve your handling except as part of a larger package or by benefit of the spring rates and ability to corner-weight the car.
5 is mostly obvious, but also includes swaybars. Many people are under the impression that swaybars are one of the first things to look at; they should be the last.
Best peice of advice I can give you is instead of piecemealing your suspension together, buy a kit. I recommend Maximum Motorsports for their grip boxes, but if you want the ultimate handling Mustang and are willing to pay for it, Griggs Racing is the way to go.
O o
/¯/______________________
\_\
Old July 30th, 2011, 12:50 PM   #29
invsn is on a distinguished road
full length welded sub frame connectors
Old July 30th, 2011, 03:00 PM   #30
8.7 1/8 mile
mwilly is on a distinguished road
Ditto what Jazzer said about Maximum Motorsports. You can find used MM stuff every once and a while on different forums. I am looking to go TA/PHB but just haven't had the money.
Threads Similar to: What are the best mods for better handling?
SN95 Handling vs 05 Handling Tyler Mac 94-95 5 August 1st, 2011 08:54 AM
Need help choosing handling mods 01MGGT 99-04 10 November 14th, 2009 05:57 PM
Best Handling Mod andres0286 99-04 15 April 17th, 2008 12:13 PM
handling zigbigadoru 96-98 11 February 21st, 2008 05:57 PM
Need Help With Handling 03blkstang 99-04 29 September 20th, 2006 04:59 AM
