2003 Mustang V6 Pony Edit
Quick '03 3.8 V6 to 4.6 V8 engine swap ... tech advice wanted
I am re-posting this on the V8 forum just to see if I can maybe get other tech advice on the swap... below is what possted on the v6.
Hey guys, OK... so, now I'm opting for the 4.6 GT engine swap. As per my BAD SOUND thread, this is the direction I'm looking at. Since I am in Canada, cost differences in buying a GT is slightly skewed. Those of you who have seen Sally III and know her issues and have read the other threads may advice a bit better. So here is where I stand: I'm making arrangements at 4.6 mustang engines with low mileage. I have someone who has the facility and equipment and necessary experience to do the swap. Given that he does it on GM's but with turbos and superchargers. I need to know what I'll be missing in the swap and so far this is what I'm seeing to need: 4.6 Engine Exhaust Manifold (I have custom true dual Mach 1 Take-offs after the cats) Entire intake assembly Wire Harnesses (plus extensions) ECM It seems that the part numbers for a v6 alternator is different form a GT so let me know if my v6 alt is useable. I'll see if I can get the engine complete with accessories. From what I know, the GT and coupe transmissions are the same... T56 is what I'm getting from the engine supplier... T5 is what I've read for both. Rear end and suspnsion can be for later (and BREMBos). Advice on the build from techies would be appreciated. A
2003 Mustang V6 Pony Edition | 1968 Mustang RS |1980 Datsun 280 ZX | 1977 Camaro with '85 Intercooler Engine | 1971 Cadillac 472 cu.in. (7.7L) Engine | 1973 Mustang 5.0 Ragtop |
Depending on the year of the GT it would have either a t-45 or 3650 for the later new edge cars. But a t56 is a great way to go. And obviously a v8 will require more fuel than a 6er. Did you check the clutch on the 4.6 to see ifit was decent? Btw you will need a different alternator for the v8. Good luck with that swap man.
Vortech'd 663rwhp 621 ft lbs |
Moderator
2012 300a gt auto
12.10@116
a small list of the things your missing,
complete fuel system, front to back radiator, fan & res. gauge cluster all the engine related hoses hydroboost system & all brake hard lines driveshaft k member all underhood air conditioning components exhaust hangers for dual exhaust sys I'm shure theres plenty I'm forgetting, but that a start. to do this swap you pretty much need a complete donor car
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
#4 | |
I YOLO way too much.
Maybe a little faster than stock
#5 | |
also n 8.8 would be nice u can get away with the 7.5 with n open diff but its not as fun. |
8.7 1/8 mile
Buy a wrecked GT that's been rear-ended. That will give you pretty much everything for your swap.
Threads Similar to: Quick '03 3.8 V6 to 4.6 V8 engine swap ... tech advice wanted
| Quick '03 3.8 V6 to 4.6 V8 engine swap ... tech advice wanted | adryan | V6 Mustangs | 9 | July 23rd, 2011 05:27 PM |
| 67 mustang engine swap need advice | Atoka Jim | Classic Mustangs | 5 | April 22nd, 2009 12:11 PM |
| TECH! - Help with head swap - Noisy engine... | 96gt226410 | 96-98 | 12 | July 14th, 2008 03:23 PM |
| engine swap? i need some advice | cobrakid | 5.0 Mustangs | 7 | January 17th, 2007 07:52 PM |
