Speakers stopped working, not sure what to look for...
Old July 24th, 2011, 08:39 PM   #1
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
So I start up my car one day to drive to work, and got NOTHING coming out of the speakers. Dead silence. The head unit (lol head) seems to be working fine. It turns on, reads CDs and everything, and even shows it is playing music (it has a visualizer display that goes up and down when music gets loud....you know what I'm talking about). But I get nothing from the speakers. I checked all fuses in both boxes, the inline 10A behind the head unit, and the inline 60A going from the battery to the amp. It had the Mach 460, but the previous owner replaced all with aftermarket, which is what worries me. It all worked perfect up to this point.
Anyways, I've never messed too much with audio so I don't know what to look for. One thing I did find is that the power LED on the amp doesn't light up, maybe that means its busted or I have a short somewhere.
If anyone has ANY suggestions they will be much appreciated. Thanks in advance, gentlemen.
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Old July 27th, 2011, 06:56 PM   #2
UnSungHero48's Avatar
1998 3.8L v6 Mustang
Dunno (I dont push her)
UnSungHero48 is on a distinguished road
Check your wiring to the amp if everything is routing to that first, then if that is true problem look at the wiring in the back of the head unit, I bet you any moneythat the "expert" before you just used splice connectors and didn't soder a thing! If not check the amp fuze on the amp itself then also the one on your amps power wire, which will most likely be in the engine bay.
Lemme know how it goes for you!
UnSungHero48
CAI, Pypes Dual Exhaust, Sony Xplod deck w/4 150watt Speakers & 12" Shallow Sub (Pioneer), custom interior lighting, crystal clear fogs w/custom relay, crystal clear headlights, stripe kit and Gold Trim w/billet grille inserts.
Old July 28th, 2011, 12:03 AM   #3
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thanks man. Turns out the 60A fuse was bad, although it didn't show any signs of being bad. I shorted the fuse and it worked again so I went and bought a new one and BOOM!
but you get reps anyways
Old August 5th, 2011, 01:39 PM   #4
BDs01MGGT's Avatar
2001 mustang gt
BDs01MGGT is on a distinguished road
my friend had this happen, it was a speaker wire that got stuck to the magnet on the back of the speaker.. pulled it off and works fine
Old August 5th, 2011, 01:40 PM   #5
BDs01MGGT's Avatar
2001 mustang gt
oh shit didnt see you solved the problem but good thing you found the problem haha
Old August 7th, 2011, 02:51 AM   #6
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Haha well thanks anyways I'll keep that in mind if I ever come across a similar problem.
Threads Similar to: Speakers stopped working, not sure what to look for...
fog light stopped working MustangGT_99 99-04 3 March 21st, 2011 02:37 PM
Heater Stopped Working mcqueen V6 Mustangs 9 February 14th, 2011 03:43 AM
window stopped working StutteringStang06 2005 - 2010 4 May 25th, 2010 02:46 PM
A/C Stopped working smokeshow 99-04 1 July 7th, 2008 04:24 PM
Odometer Stopped Working 1995svtcobra 94-95 22 July 16th, 2007 07:46 PM
