TIRESSSSSSSS NEED HELP!!!! people with knowledge
Old July 25th, 2011, 01:15 PM   #1
mystk96's Avatar
2005 trd tacoma sport
mystk96 will become famous soon enough
so ive decided to go with a different set of wheels on the mach now im curious to know what tires are as good as the bfg kdw 2's
they dont come in a 295 or 315 tire for a 17inch rim so i have to look elsewhere, ive looked into the nitto invos and the nt05s but i fear they will be to soft for daily driving, dont really give a shit about summer to all season tires just want something that are just as good as the bfg kdw 2 tires, i truthfully dont know to much about tires so anyone with some knowledge would be great
Old July 25th, 2011, 07:09 PM   #2
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
As I always say...
Tires should be chosen by the drivers needs and decided by the budget
What kind of grip do you need? Saying as good as the KDW2 is really not enough, as they are a latteral grip tire. Do you....
DD with occasional 1/4 mile?
DD with LOTS of 1/4 mile?
DD with some twisties?
DD with AS MANY TURNS AS YOU CAN POSSIBLY MAKE BECAUSE YOU ARE ALLERGIC TO A STEERING WHEEL THAT IS POINTED DIRECTLY IN FRONT OF YOUR CAR?
What size wheels are you going to be running up front and out back?
What year ride will these be used? (I only see a Tacoma in your sig)
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old July 25th, 2011, 11:57 PM   #3
sj408 will become famous soon enough
Ive been through quite a few brands of tires, bfgoodrich g sports, nankang, falken azenis and ziex and fk452, lexani and nexen n3000s
i just bought nitto nt555s for my rear and i will say that ive never had such a nice tire for cornering and grip. If im attentive i cannot even break these things lose through the corner where any of the other tires would have broke loose and lost traction
Old July 26th, 2011, 08:38 AM   #4
mystk96's Avatar
ive had a bad experience with nittos (555s)
and jazzer its a 04 mach 1 right now its sits on 95 deep dish cobra r's 18x9 18x10 however i want to switch to a 17x9 and 17x10 wheel 255 up front due to rubbing issues and 295 rear not really sure if a 315 will fit without rubbing the 295s roll under close as hell to the fender on axle articulation
found some kumhos but tread wear has a horrible rating
Old July 26th, 2011, 09:59 AM   #5
Abyssinian of AX
'02 Saleen
19.34@42.259
Horrible tread wear rating is a relative thing I run as low a tread wear rating as I can find that is street legal
You will not properly fit a 315 on a 10" wheel, so 305's is the max. What are your needs as a driver...
DD with some 1/4 mile?
DD while RIPPIN' DA CORNERS AS OFTEN AS HUMANLY POSSIBLE? *you would be my hero*
Jazzer
Old July 26th, 2011, 04:59 PM   #6
mystk96's Avatar
DD with A LOT of twisties, its never raced since we live in the mtns now.
Old July 29th, 2011, 10:57 AM   #7
2000 mustang gt vert
doubleohvert is on a distinguished road
I don't like my nitto555s or my nt05s. they both suck. the nt05 has a hair bit more straight line traction, but the 555s after about 5k your better off driving on the rim alone. the 555s last quite a while but the nt05, not so much. i love my kdw2 on the front. i got 245/45 17 front and 315/35/17 rear. when it comes time for new tires im going with the kumho ecsta spt for its price and tread wear rating. If you just want a decent tire with no regards to price or tread rating, look into the kumho ecsta xp. I've heard good things about that tire
Old July 29th, 2011, 10:59 AM   #8
and I had the nt555s when i bought my wheels 2yrs go. replaced them with the nt05s 4 months ago, one blew out last month so i had to get another nt555 because it was the cheapest tire could overnight.
Old July 29th, 2011, 01:21 PM   #9
Abyssinian of AX
'02 Saleen
19.34@42.259
You need to be specific here....
Are we talking NT555's or NT555R's? Either way, if you are getting only 5K miles off of them, you are dumping the clutch at every single stop light and being consumed by the smoke emulating from beneath your ride
The 555R's will give you a solid 8K~10K miles even with 10 HPDE days a year. This is what I do and got about 8K from my 888's. The difference being, I run a lot of negative camber up front and they get heat cycled out by this time.
The Kumho Ecsta SPT will give you FAR better mileage than the NT555R's and probably a bit better than the NT555's, but ALL of this depends on one keeping the tires in contact with the road surface and not buring them off.
Jazzer
Old July 29th, 2011, 03:06 PM   #10
mystk96's Avatar
so whats a good 17inch tire, the car is driven in the mountains
Old July 29th, 2011, 05:32 PM   #11
Jazzer
the nt555 like stated. they lasted almost 2yrs, but after about 5k they had no traction. full tread, just no grip. the first 5k they got excellent grip. and the nt05 where better in the rain and still get decent traction, but after about 4 months of use its worn down to almost the wear bars
Old July 29th, 2011, 08:27 PM   #12
Abyssinian of AX
'02 Saleen
19.34@42.259
So NOT the R's.... hmmmmm
Sounds like they were heat-cycled out, but never heard of such a concern on a 300 UTQG tire
Did you like run them in freezing temps or extreme temps a lot or..... ?
Jazzer = Befuddled
Old July 30th, 2011, 12:49 PM   #13
invsn is on a distinguished road
I have mickey thompson et streets... 315/35/17 and i have no tire slip at all. The grip in these tires are insane..im pushing 450 to the wheels
Old July 30th, 2011, 03:32 PM   #14
mystk96's Avatar
yea but how long do they last, how do they handle in the rain
Old July 30th, 2011, 03:45 PM   #15
have drove on them in below freezing temps, and trust me they really suck on ice. lol But they lost grip before that. they did alright at best in the rain when i had traction control on, but now that my abs module is bad they're horrible in the rain. the NT05 is a much better tire in my opinion as far as rain driving, straight line grip and corner grip, but they only lasted 1/3 of what my 555s lasted.
Old July 30th, 2011, 06:02 PM   #16
Mickey's arnt too bad in the rain... but i dont drive it hard and wouldnt expect anyone to in the rain..I put a set on at around 23,000miles and i just replaced them at 60,000
Old July 31st, 2011, 03:43 AM   #17
Wyatt's #1 Slut
B's04gt's Avatar
N/A
B's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to all
Not meaning to thread jack just asking a question trying to get a usefull answer..
how well are 555's compared to nt05's DailyDriven? Weather including heat 100* and rain
Mods: -Eibach Pro Kit - K&N - Tuned for 91 octane - visual shit-
i'm definitely confused by this. i feel like a little unwitting gay boy that's seen another boy's penis for the first time.
i love Uranus
Old July 31st, 2011, 07:13 AM   #18
Abyssinian of AX
'02 Saleen
19.34@42.259
^ I run them from somewhere in April to October and love them for street use
They sound a LOT like a low-flying crop-duster plane, depending on the road surface. They offer improved grip over the PS2's (fantastic tire, BTW!) I run on my Winter wheels, so worth it to me. I have never driven the NT05's, but certain would not be as good as them in the heavy wet. In general, I don't like to drive them in the wet anyway. When I do, VERY conservatively do I drive, as I run very wide tires as well and hydro-whohooing is not fun when you don't plan it
Jazzer
Old August 1st, 2011, 09:36 PM   #19
2001 Mustang GT
Stlhrse is on a distinguished road
I have only run the Nitto 555's (had only bought 3 sets since 2001), I have good experiences with them. I am due for a new set....The cheapest I found for a 245/45/17 size is usually from Discount Tire Direct.com....IMO, the overall price and purchasing experience is A1. Checkout their site, especially w/ free shipping, and depending on where you live (state) no tax. Their tire replacement warranty is great, never had it so easy.
Old August 4th, 2011, 11:19 PM   #20
jrivero512's Avatar
2003 Mustang Gt
jrivero512 is on a distinguished road
i have Falken AZENIS RT-615.... all i can say is these tires have not disappointed, went threw a set of nitto 555r's and sumittomo htrz. They r no where near how good the falkens have been im running on 35,000miles and still look brand new u can get them on vulcantire.com, the website some times has great sales but u gotta get them at the right time i got mine for $85 a piece now there at $231..
Threads Similar to: TIRESSSSSSSS NEED HELP!!!! people with knowledge
Tax Knowledge Needed fmxona500 The Clubhouse 5 December 2nd, 2010 09:08 AM
Tax Knowledge Needed fmxona500 The Clubhouse 0 December 1st, 2010 10:42 PM
people with knowledge on diesel engines, get in here! kyle2002stang! The Clubhouse 6 June 29th, 2010 07:18 PM
Small business people. (and anyone with knowledge) Dansby The Clubhouse 41 October 30th, 2009 01:53 PM
knowledge base sgrcltpunk Feedback Forum 5 February 4th, 2009 09:27 AM
