#1 | ||
car wont start
Just installed supercharger and intercooler, did everything, flashed it, car wont even attempt to start.. any ideas?
#2 | ||
could it be that i installed the tune and everything but i didn't hook up the boost a pump? i was gonna start it and just let it idle because i wanted to check for leaks but i guess maybe once i install the boost a pump it will work?? come on guys give me some time
let me get this straight...
do you have no crabk no start or crank no start???? did you drive your car after the installs????? it could be as simple as a relay or a fuse.... this might sound stupid but i see it at the shop a lot ... do you have gas.... after you flashed it did you notice your electricals working as in dash or interior lights i have seen severl techs burn PCM's when using scanners on vehicals... they didn't turn the key before turning on the scanner.... check your connectors...such as air intake...o2..... without a signal from them the PCM will not go into closed loop(or start the vehical) good luck...and let us know!!! TGIF..
and is the battery bolts tight. we see that alot they change a battery out and just shove the terminals on and dont tighten them up, they get just enough power to do little things bt cant draw enough to start
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
Threads Similar to: car wont start
| Wont Start | caintcatchmyGT | 96-98 | 3 | September 10th, 2007 11:02 PM |
| wont start | snailstang | 96-98 | 24 | August 30th, 2007 09:46 AM |
| need help...car wont start | orlyr21 | V6 Mustangs | 8 | January 13th, 2007 08:17 PM |
| wont start?? | shadowgames81 | 5.0 Mustangs | 10 | January 7th, 2007 09:10 PM |
| 91-92 5.0 gt wont start | sturcotte3 | 5.0 Mustangs | 0 | January 1st, 2007 05:40 PM |
