Gauge Cluster
I have look around on the internet for ways to remove my headlight knob so that I can get to my gauge cluster but all I find is something saying you have to use a bent nail and pry the lever up. I have tried this for about an hour and it isnt working. How the hell do you get this shit off?
JLT CAI Magnaflow Catback X-pipe 2.8 Pulley 4.10's
Well, first of all calm down cause youre swearing. :wink
Second of all where have i seen that car, what other forums are you on ? And lastly....get a flashlight. get a 45 degree angle pick or a screwdriver ( a bit harder of a time with a screwdriver ) Very small though. Then turn youre light switch until you see a hole with a triangle thing in it. Then stick in the pick and pull up while you pull out on youre light switch. comes right off.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
I looked in there with a flashlight, all I see is a black metal rod, I dont see any triangle looking thing at all.
If you keep turning it until you can see the shaft there will be a black triangle looking tab twords the end of the knob.
1998 Z28
Im guessing the cobra light knob is different from the 99-04 GT's
I just pull mine off (with my hands) and then I can slide off the triangle piece off and put it back on!
Unknown
Nope still dosnt work.
no they are not diferent....what happens for you is what happens when it breaks.
![]() I wish i had a pic, so i could help you out.
#8 | |
1998 Z28
Actually No not broken at all (Just used a shortcut my dad showed me a few years ago)! When (I PULL) off the knob the triangle piece is still on the rod, then I pull off the triangular piece off the rod, then when I go to put it back on I use a pin or a phillips head to put the metal piece back in to the knob and then slide it back onto the rod , like magic it's a snug fit! I installed my white face guage 3 weeks ago!
Unknown
Threads Similar to: Gauge Cluster
| GAUGE CLUSTER | BROKINARROW | 5.0 Mustangs | 8 | October 5th, 2007 07:17 PM |
| Gauge Cluster | Euroeater95 | 94-95 | 2 | May 20th, 2007 09:55 AM |
| gauge cluster | coreyfitz | 94-95 | 2 | April 14th, 2007 07:37 PM |
| swapping '95 V6 gauge cluster to a '94-'98 GT cluster? | Alocatelli | V6 Mustangs | 3 | April 4th, 2007 03:38 PM |
| 06 Gauge Cluster Lighting? | Baldingo540 | Audio/Video | 2 | October 16th, 2006 06:33 PM |
