Discussing what is the correct fuel pressure in the Modular Mustangs Forum. my 98 seems to be running out of fuel and doesnt like to start right ...
Old May 20th, 2007, 12:31 AM   #1
beheivjer's Avatar
my 98 seems to be running out of fuel and doesnt like to start right away what is the stock fuel pressure on my 98 gt. any ideas thanks guys/gals
1966 LUBR Bronco
1979 2.3t Cobra
1994 V6 Vert & a 351 ON A STAND
1997 Black Cobra
1994 Jeep XJ 4.5" lift 33"MTR
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old May 20th, 2007, 12:41 AM   #2
All Throttle with a Bottle
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
I believe its somewhere between 35 and 45 PSI! For somereason 40 PSI sticks in my mind!
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Old May 20th, 2007, 12:44 AM   #3
beheivjer's Avatar
thanks that what i was thinking the killer is i put a pump in it last july and its starting to go already. it was a pain changing it on a hoist and this time i have to do it on the ground
might just have to park the car for a while and drive the 79 while i finish my kitchen remodel and my garage build maybe 3 weeks then ill have a place to do the job.
1966 LUBR Bronco
1979 2.3t Cobra
1997 Black Cobra
Old May 21st, 2007, 08:01 AM   #4
the fuel pressure on a '98 gt with the engine running is 30-45 psi.
key on engine of 37 - 43 psi...
hope this helps.....
Old May 21st, 2007, 08:02 AM   #5
that was engine offffff.....37 -43 psi way toooo earily for this...
Old May 21st, 2007, 09:00 AM   #6
beheivjer's Avatar
thanks i guess im just going to put my fuel pressure gauge in that ive had sitting around for almost a year now
1966 LUBR Bronco
1979 2.3t Cobra
1997 Black Cobra
Old May 23rd, 2007, 02:41 AM   #7
beheivjer's Avatar
well acording to my guage it is reading 30 psi while running and flutters down below every so often and when im hard on it it runs up to about 35 but thats it. I did change out the regulator and it is atleast up to much now instead of the 20-25 i was running.
so fuel pump? or inertia switch? if i trip it and start it it runs up to 35 at idle but only once and then the next time its back to 30.
1966 LUBR Bronco
1979 2.3t Cobra
1997 Black Cobra
Old May 23rd, 2007, 08:28 AM   #8
a quick question....when was the last time you changed your fuel filter????
it could be the issue here!!
and are you the original owner.???...maintenance wise.. the other owner may not have taken good care as in what kind of fuel they bought...
dirty cheap gas leads to clogged fuel filter and fuel pump filter and dirty injectors and so on....
let us know!!!
Old May 23rd, 2007, 09:51 AM   #9
beheivjer's Avatar
new pump new filter im a autoparts slaesman, i know the drill. did both of these when in july last year i bought the car in feb 06. so previous owners flaws would have shown long before now. all the injectors were of and pressure checked in june of last year when i swapped in the pi manifold
1966 LUBR Bronco
1979 2.3t Cobra
1997 Black Cobra
Old May 23rd, 2007, 09:53 AM   #10
MuchCoolerThanGTsetGO
ChrisJ's Avatar
SLOW
Sounds like if you flip the intertia switch and it runs good then it starts runnign bad again...I would say it would be the intertia switch...
My Junk
www.myspace.com/cjobe
Old May 23rd, 2007, 09:59 AM   #11
Casper98GT's Avatar
well you cant exactly just "flip" a swtich when talking about the intertia switch.
Why would you even consider the inertia switch ? When you have I.S. problems its usually a crank but no start. What exactly is it doing, you will have NO fuel pressure if you have a bad I.S. Its a fuel cut off. Find the I.S. and hit it with youre hand and see if it pop's up. If it does push it back down. If you honestly have youre mind set on it just jump the wires and rule it out.
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Old May 23rd, 2007, 10:35 AM   #12
ChrisJ's Avatar
SLOW
I have seen a faulty inertia switch short itself and give false readings and such...Im just trying to get him to rule thigns out...
Also how exactly are you reading the fuel pressure? I know you said a gauge but did not know if you might ahve tried another method...
Also how does the car run when it flutters?
Could all wind up being a bad sensor or gauge...
My Junk
Old May 23rd, 2007, 12:24 PM   #13
Casper98GT's Avatar
Im just saying the I.S isnt the problem if it starts. It could very well stall out due to the switch. I didnt remember readings a stalling condition.
Just that it seems to be running out of fuel and sometimes take a while to crank.
White99stang-
Ford/Toyota tech.
Old May 23rd, 2007, 12:30 PM   #14
ChrisJ's Avatar
SLOW
I am guessing you are not getting any trouble coeds either are ya?
The main thing that has me stuck on the switch is that when he messes with it then his fuel pressure goes up to 35...
Double check all the fuel lines to make sure they are secure and in good repair...
Try and see if we can fix this without you having to buy anything...
My Junk
Old May 23rd, 2007, 12:33 PM   #15
Casper98GT's Avatar
dude, not to start a war but you tell me right now in a technical way how a inertia switch makes the fuel pressure regulated. I honestly wanna know. You tell me how a on/off switch makes fuel pressure jump.
White99stang-
Ford/Toyota tech.
Old May 23rd, 2007, 12:52 PM   #16
ChrisJ's Avatar
SLOW
I was talking about it stalling...I mis-read the earlier posts by him...I thought the car was stalling out...
I really have no clue how the inertia switch would have any way to fluctuate the pressure...The only way I could think of is if it is fluctuating the power to the fuel pump...And then that would effect the fuel pressure...
Im jsut trying to give ideas of what it could be...This used to be a big issue with the fox bodies...
My Junk
Old May 24th, 2007, 09:10 AM   #17
beheivjer's Avatar
if the inertia switch start to go on some vehicles it will allow the pump to work but not enough to run, i personally have had it happen on my sable wagon. its odd but it has happened thats why i ask.
1966 LUBR Bronco
1979 2.3t Cobra
1997 Black Cobra
Old May 24th, 2007, 09:12 AM   #18
beheivjer's Avatar
i have a fuel pressure testor the connects to the fuel rail and then i have a autometter gauge in the car. It is a comp electrical gauge and the both read the same so i dont think i have a bad gauge.
1966 LUBR Bronco
1979 2.3t Cobra
1997 Black Cobra
Threads Similar to: what is the correct fuel pressure
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 12:41 PM
Fuel pressure 8A_Honda 5.0 Mustangs 1 August 16th, 2007 09:53 AM
Fuel Injectors/fuel pressure 00silvergt 99-04 4 August 2nd, 2007 10:54 AM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 07:58 PM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 04:31 PM
