What's the tell-tale sign of a bad ball joint?
Old August 30th, 2011, 10:48 PM   #1
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
My front passenger side has been making some weird noises the last month or so, progressively getting slowly worse. Seems to make more noise when turning the wheel to the right. The sound is hard to describe. lower pitch, either rubber on metal or rubber on rubber. Kind of like a creak. sometimes sounds like a pop.
Opinions? Let me know if you need a better description
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Old August 31st, 2011, 09:44 AM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
The tell-tale sign is when there is play in the joint. Jack the car up (place it safely on jackstands), put your hands on the tire top and bottom, and give it a wiggle to see if you have any movement in the joint. Another way to check while the car is up on jackstands is to place a bar under the tire and lift up. Watch for any play in the balljoint.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old September 1st, 2011, 09:01 PM   #3
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
there is a little wiggle, but barely. Like not even a millimeter. Almost as if i didnt quite tighten the lug nuts all the way
Old September 1st, 2011, 11:05 PM   #4
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Make sure your lug nuts are tight lol
Also shake it side to side. If the play is the same its a wheel bearing
410rwhp 520rwtq @ 12.9 psi
Old September 1st, 2011, 11:14 PM   #5
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Its not really a groaning like I'd expect from a wheel bearing.
I was thinking of upgrading anyways, how reputable are these? 1994-04 Mustang Front Mild Steel Tubular Control with Spring Cups at LRS - Same Day Shipping!
Old September 4th, 2011, 12:50 AM   #6
Macunicorn's Avatar
Macunicorn will become famous soon enough
I noticed with mine I had a bad ball joint when I went to full lock on steering it made a popping noise. I also could feel a bit of shaking in the wheel as well.
I just replaced the entire front arms also with new control arm bushings.
Sig by Tricep
Old September 5th, 2011, 07:58 PM   #7
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Did that solve the problem?
Old September 5th, 2011, 09:24 PM   #8
Macunicorn's Avatar
Ya for me it did yes. You can test it by jacking up the front and moving the tire side to side and forward and back too.
That could also be a tierod starting to go out. Or could be as simple as a bushing needing grease.
Sig by Tricep
Old September 11th, 2011, 12:47 PM   #9
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
The noise turned out to be the aftermarket air filter banging around.... i feel so dumb hahaha
Old September 13th, 2011, 10:04 PM   #10
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
just secured the air filter but the noise is still there. Here are some vids of me jacking up the car slowly and it seems to be moving stifffly.
Old September 13th, 2011, 11:09 PM   #11
Tang Stang's Avatar
It's hard to tell what is making noise and where the noise(s) are coming from without being there in person. Did you try putting the car on jackstands, placing a bar under the tire, and lifting yet?
Old September 14th, 2011, 03:41 AM   #12
96gtstang&V6's Avatar
96gtstang&V6 is on a distinguished road
Sir theres a nail in your tire.. 0:15
2002 mustang v6- Auto, K&N CAI, Flowmaster dual exhaust, Black bullits dd
1996 mustang gt- 5spd, black, cobra hood, stock
November Birthday Club Founder
Old username: 97gt
www.discounttiredirect.com
Old September 14th, 2011, 03:48 AM   #13
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
RedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really nice
Are you sure it's a nail lol? It looks like it's debris from white rock or concrete
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok.
05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel
Old September 15th, 2011, 09:14 PM   #14
1998 Mustang GT
MustGT98allday will become famous soon enough
i would do like tang stang says and lift up on the tire with a bar while its jacked up. Also if you move the tire left to right while its jacked up and feel play or knocking it could be either of your tie rods. You should be able to tell from those two things. But if its all tight and no play than check your sway bar links too
pi swapped and dropped sn95
Old September 16th, 2011, 08:13 PM   #15
mustang50lx's Avatar
mustang50lx is on a distinguished road
Get a stethoscope from a parts store or Sears and listen to the ball joints, tie rods, etc. while someone steers the wheels back and forth. Creaking ball joints and tie rods are not uncommon on Fords. I just put a ball joint in my Crown Victoria for that reason. It had no play in it. Make sure you put the parking brake on, the car in park, and block the wheels while laying under the car. You don't want to get run over.
Old September 19th, 2011, 04:34 PM   #16
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
I will have to try that when I get free time. Thanks for the advice guys, reps all around.
Old September 21st, 2011, 02:52 PM   #17
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
You have to unload the balljoint before you test for play. with the car on jackstands put a jack under the lower control arm and jack it up a little. You wont see play unless you do this because the ball joint would still be loaded.
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
Old September 23rd, 2011, 04:01 PM   #18
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
Have you tried greasing them? I had the same issue, greased ball joints and tie rod ends and no more annoying sounds.
Threads Similar to: What's the tell-tale sign of a bad ball joint?
A arm/ball joint question S281 99-04 2 November 19th, 2010 07:33 PM
ball joint help Ryguy33 99-04 7 July 8th, 2010 12:58 AM
Ball joint? stang05 2005 - 2010 V6 4 January 25th, 2010 10:21 PM
I think I have a bad ball joint.. RAGEman 99-04 5 February 25th, 2009 11:11 AM
ball joint probels zmaier 96-98 1 September 1st, 2008 01:18 PM
