LEDs in gauge cluster question
Old September 13th, 2011, 02:13 PM   #1
Saleen0101's Avatar
2001 Saleen 281 #0101
Saleen0101 is on a distinguished road
Hello, I swapped my incandescent #74bulbs to led #74 (the 5 lights in the back of the gauge cluster) as they look sweet , but when no lights are on, my odometer and clock in my stock radio are dim as if I had set the dimmer to the lowest setting. If I turn the lights on , the odometer and radio light up like normal. I dont really like this and wondering if any of you that have done this have found a remedy or if anyone who has swapped led themselves had this issue? My car is a 2001 by the way thanks for any input.
Old September 13th, 2011, 08:08 PM   #2
Saleen0101's Avatar
Anyone?
Old September 13th, 2011, 08:24 PM   #3
WhiteNoise's Avatar
1997 Mustang GT
WhiteNoise will become famous soon enough
I recently installed the LED's but didnt have this problem. The only thing i found is that the LED's dont dim as low as the previous bulbs. But it seems that something is backwards. They should dim when lights are on and normal when lights are off... Did you only unplug the guage cluster? The cluster shouldnt have effected the stereo at all...
Mods: MAC o/r H, SCT tuner, CAI, short throw shifter, dash LED conversion Upcoming: Suspension build (Spring/Summer 2012)
Old September 13th, 2011, 08:29 PM   #4
Saleen0101's Avatar
interesting. Wonder what could be backwards then. I just unplugged both on the back of the cluster and swapped out 5 bulbs only, i put my incandescent lights back in ;( and it is normal again
Could It be that I didnt have the led correctly put it ?? I have no idea what to do man
Old September 13th, 2011, 08:42 PM   #5
Saleen0101's Avatar
Or could reverse polarity cause this upon installing the leds? They all lit up fine the first time I put them in ,
Old September 15th, 2011, 05:33 PM   #6
Bangarang's Avatar
Bangarang is on a distinguished road
I don't know but what color did you get? I was thinking about get the 74 Blue blubs from SuperBrightLEDs.
3.73 Gears, Flowmaster 40's, CAI, 1.5" drop, Diablo Tune, Cosmetics.
TOTALED
We can rebuild her, we have the technology...
Old September 15th, 2011, 05:54 PM   #7
Saleen0101's Avatar
Well Im thinking it was because I had cheap china leds, they were left over from my gf buying them for her car. They were the super white color and only a single led on the head of the bulb so brightness wise it was the same as the incandescent lighting. I just ordered the #74hpx3 from superbrightleds.com and will let you know how it works out, im anticipating it to be very bright, as these are smd leds.
Old September 15th, 2011, 05:58 PM   #8
Bangarang's Avatar
Hey that could be it. Maybe the problem will be solved now that you're getting better quality.
TOTALED
Old September 15th, 2011, 06:01 PM   #9
Saleen0101's Avatar
Yea, i agree. Or maybe one of them just wasnt in snug all the way, I noticed when I took one out it was loose so that probably was it.
Old September 15th, 2011, 09:09 PM   #10
WhiteNoise's Avatar
1997 Mustang GT
Dont get the cheap ones, bad quality. Iv got all of my LEDs from superbrightleds.com. That was probably your problem! And remember, the guage cluster has a blue tint to it already. I installed the "bright white" leds and they turned out the perfect blue. If you get a dark blue bulb, it might be too dark (unless thats what ur aiming for). If ur going for a different color, u might need to sand off the blue film on the cluster( its actually inside the cluster so ud have to take it farther apart that when u just install the lights).
Heres mine with the "bright white" LED's in.
You cant really tell, but i also did the HVAC lights too.
I also installed a blue LED in the dome light. Blue obviously..
Old September 19th, 2011, 06:00 PM   #11
Saleen0101's Avatar
Well got the leds from superbright leds, installed them and still the same problem remains. When the lights are all on , everything works fine, however with the lights off and I turn on the right turn signal, my odometer and radio flash with the turn signal..wtf?? Im assuming not enoigh volts hitting my cluster and its causing issues.
Old September 19th, 2011, 09:31 PM   #12
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I did this swap and did not have any issues at all. Except the dash lights don't really dim much with the led's, if at all.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old September 19th, 2011, 11:56 PM   #13
sj408 will become famous soon enough
heres a write up on how to do it How to Install LED lights in your Mustang Gauge Cluster
Old September 20th, 2011, 02:07 AM   #14
Saleen0101's Avatar
Well you guys all have sn95 (mines a 2001 and plus I have the saleen gauge cluster) But I dunno why my odometer and radio flash when all lights are off and if I have have the turn signal on. If all lights are on at night, I have no issues, Any ideas guys? Sucks I cant have leds ;(
All lights on my exterior have been swapped out to leds.
Old September 23rd, 2011, 05:13 PM   #15
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
the saleen cluster is a stock cluster with a new overlay. All the guts are the same as a stock cluster so that should not have anything to do with it.
MODS IN GARAGE
NCMM ORIGINAL
Old September 26th, 2011, 02:49 AM   #16
Saleen0101's Avatar
Yes same problem with me too, I believe its the voltage , not enough hitting the cluster causing strange problems, with all my lights on , no issues, however when lights are off, the odometer and radio are dim. Like if I turn the dimmer all the way to the right to dim, and of course the blinker , everything blinks with the turn signal .
Threads Similar to: LEDs in gauge cluster question
2001 gt gauge cluster question sinclair01gt 99-04 4 February 28th, 2011 09:19 PM
Gauge Cluster question? Rich11 99-04 11 January 2nd, 2011 04:04 PM
Gauge cluster question orangestang42 5.0 Mustangs 4 November 12th, 2010 12:54 AM
gauge leds ZoomZoomMFer 99-04 8 August 8th, 2008 08:39 PM
gauge leds ZoomZoomMFer The Clubhouse 3 August 8th, 2008 08:38 PM
