Grille Delete
Old May 23rd, 2007, 09:25 PM   #1
HessiaN257's Avatar
13.9@101
HessiaN257 is on a distinguished road
Grille Delete
I recently ordered a 3 piece grill delete for my 2000 GT. The kit says it doesn't come with the hardware I need to install it. Anyone know what hardware I need? Sizes of bolts, ect.?
Thanks
13.9@101 before some mods
Old May 23rd, 2007, 09:37 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Removing the stock grille from the car:
First, you need to remove the 4 retaining screws on the top of the factory grille, as well as removing the two retaining screws that hold down the stock fascia. This is fairly simple to do, but take your time, as you do not want to scratch your paint.
Next, tilt the factory corral forward just enough so you can get to the four 7mm bolts that hold the factory corral grille at the bottom.
Congrats, you are now halfway done!
Installing the Three Piece Mach 1 Grille Delete Kit:
Take the backing piece (the one with the two circular holes) and install that using the two plastic retainers in the lower corners of the delete kit. Next, take the bottom lip of the delete kit and insert the two plastic retainers into the top of the fascia. Line up the four studs at the base and place them into the factory drilled holes in the bumper and secure them with fascia tabs. Finally, take the pony and mount it into the rear bracket using two screws. We suggest going to your local Ford dealer and getting a set of factory security torx bit screws so that your pony cannot be stolen off of your car.
Thats it, you're done! Go cruise and show off that Stang!
Threads Similar to: Grille Delete
grille delete 04gtvert 99-04 13 August 12th, 2007 12:16 AM
grille delete kit Kennhyy3 V6 Mustangs 8 January 18th, 2007 05:32 PM
Grille Delete 04Pony 99-04 12 December 19th, 2006 02:47 AM
Grille Delete Kit Outlaw GT 99-04 18 November 21st, 2006 02:06 AM
