What's your current HP and what are your HP Goals?
Im new to the board and I was wanting to get to know about the board
members mustangs: What year and model do you have What are your current mods and estimated HP What is your HP goal and what mods are you going to get to obtain that HP. I plan on getting an 05-08 GT and I want around 450 HP and still be able to use it as a daily driver(even though I won't be driving it every day). Don't know how I'm going to reach that HP though. |
Traction...?
1996 GT/ 2008 GT Vert
1996 GT
CAI, 3.73's, exhaust 220 maybe? 300 is my end goal: pi swap, headers, tune, CAI, 3.73s, stage II cams and possibly underdrive pullies 2008 GT 300 310 CAI the rest to be left stock '05-'08's internals are only good till 450. |
2006 Mustang GT
I have a 2006 GT
Mods: 4:10s steeda cai roush m90 supercharger kit @7lbs single chamber mufflers that dynoed at 393whp and 352ftlbs i have since then put long tubes on and ditched the cats. I also have stage 2 blower cams and have not got the chance to put them in yet. I plan on forging the internals and putting a tvs2300 on there and am planning on building the car for 600-650whp. possibly more depending on how things go |
Traction...?
To be honest, im not an expert at the 3v. I know my 2v's very well though. My 3v is bone stock. As far as im aware rods and pistons, crank should be okay and watch out on the heads, if you dont take out the plus often and antisieze them they will get stuck and strip, we had a hard time getting them out after we bought it.
2010 Mustang GT
2010 GT trac-pak 528.8 rwhp..going for 575-600rwhp
![]() JBA LT`s,JBA H pipe,Pypes M-80,Detroit Cams, Rollers,Vortech V3 HO,BAP,CMDP,Tokico Adj shocks/struts,KR springs,UMI LCA`s,UMI UCA`s,UMI relocation bracket,panhard bar,MGW shifter,18x9 front 18x11.5 rear WWW.SCWILDHORSES.COM
1989 LX Coupe
7.1@99mph
1989 LX coupe
4.6 Lincoln Avi Motor 437rwhp NA 592rwhp small shot Im happy now. End goal...600+rwhp on motor, 800rwhp on spray and 8 sec 1/4...
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
96 Mustang GT
Stock But I do hope to find a set of SVO head and intake, I don't plan on heavily modding the car, and I want 280 rwhp or a bit higher Though, when I earn enough money, I want a 03/04 Cobra, and I would heavily mod it. End goal for that would be around 600 rwhp. |
2000 GT
Current mods cold air intake and straight pipes. Not sure how much hp but im guessing around 260. The motor will be pulled out in the spring and rebuilt by R&R perfomance in Huntsville, AL and it will be bored over and all new internals put in it. Then a turbo will be going on shortly after that. Im shooting for 500-550 rwhp.
2000 Mustang GT, auto, straight pipes, turbo build to come
MM's king of Neon's
404 - car not found
17.81@87
Vehicle: 2000 Mustang GT
Old setup: Engine: P71 Interceptor Trans: Mach 1 T3650 Mods (performance only): 3.55 in 04 Cobra IRS, CAI, O/R X, flowmasters, alum driveshaft, alum flywheel, Cobra fuel tank, dual GT pumps, PPRV delete, dual FPDM Power (est): 240hp Current setup: Engine: None Trans: None Mods: Special "drivetrain delete mod" reduces weight by ~700lb Power (accuate): 0hp Future setup (as soon as I finish installing it): Engine: 2003 SVT Cobra Trans: 26 spline T56 Mods: 3.55 04 Cobra IRS, O/R X, flowmasters, alum driveshaft, alum flywheel, Cobra fuel tank, dual GT pumps, PPRV delete, dual FPDM, ported blower, 3.1 pulley, FR500 cams +4deg, Hooker LT's, 60lb/hr injectors, Fluidyne HE Power (goal): 550rwhp
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2003 Mustang GT V3
2003 GT
Old Setup: Affucab 75mm tb and plenum, bbk shorties, magnaflow o/r-x, magnaflow mufflers 3.73 gears, short throw Aluminum driveshaft Vortech V3 SQ kit @ 7psi 401rwhp/398rwtq New Setup (in progress): 5.8 DOHC (bored/sleeved 5.4 Navi of some sort) Ported FGT heads, oversized valve seats Custom Cams (232/228~ish) '00 Cobra R lower, fabbed upper 50 lb+ injectors (not sure yet) Custom Pistons with 11.5+ compression ratio Custom Kooks headers with x T-56, 26 spline input, 31 output (i think) Built 8.8 Rear end...(Strange?) ....blah blah blah.... Power Goal: 500rwhp/500rwtq |
2003 Mach 1
2003 Mach 1
NOW: KB 2.1, L/T's and full exhaust, 4.10's, tubular suspension, FLSFC, LCA/UCA's, other smaller shit, shifter, etc... 497rwhp FUTURE: Forged motor, 18+psi from the KB, Auto swap. End goal is whatever the KB can manage to breathe out, hp wise with custom cams, and a sub-10.5 second pass.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons. 497hp, 460tq. |
2003 MUSTANG GT
![]() ![]() ![]() ![]() iTrader: 10 reviews
This is gonna look familiar :shifteyes
Old setup: Engine: 2003 GT 4.6 n/a Trans: T3650 Mods (performance only):4.10's, CAI, Catted X, flowmasters, tune Power (est): 250hp Current setup: Engine: None Trans: None Mods: Special "drivetrain delete mod" reduces weight by ~700lb Power (accuate): 0hp Future setup (as soon as I finish installing it): Engine: MMR 4.75 Stroker 1000 bored .020 over, 9.27:1 CR, Teksid block, Posi Race ported Eaton Trans: Stock TR3560 for now/till it breaks Mods: 3.55's, LT Headers, O/R X, flowmasters, alum flywheel, Fore hat with dual GT pumps, KB BAP, 60lb injectors, dual FPDM, Posi Race Ported Eaton, 2.9 pulley, EGR delete, etc... Power Goal: 575rwhp, 550rwtq __________________
![]() 4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton 4v MMR Stroker 1000 / Posi Race Ported Eaton Build How To: 2v to 4v COP Swap |
2006 Mustang GT
2006 Mustang GT
Hellion 76MM Turbo Kit-390 rwhp/rwt Goal is 700rwhp with a built shortblock and a 4R70W Transmission 2007 Shelby GT500 Stock Basic up grades-Headers, Pulley, Tune What ever Horsepower that gets me
1998 Grand Prix GTP Supercharged- The Daily Driver 2006 Screaming Yellow GT- Hellion 76mm Turbo Kit Tuned by Appalachian Performance, Black Mountain NC. 2007 Alloy GT 500- VMP 2.59 Pulley and Tune
#15 | |
2003 Mustang Mach 1
![]() I'm bone stock right now, so I'd like to think I'm around 270rwhp Not sure if I'm staying n/a yet, but I'd like to be at least over 300rwhp from bolt ons |
2006 Mustang GT
2006 Mustang GT
Currently bone stock performance wise Plans for it (after college im a junior in HS )Livernois forged rotating assembly Roush R2300 supercharger Phase 2 dual belt kit Tremec TR-6060 six-speed manual transmission With supporting mods Power goal: 475-500 rwhp Im not exactly the most educated in this area but im learning don't bash ![]() I haven't done to much research because if i ever reach my power goal its gonna be in atleast another 10 years
![]() 2006 GT 5spd - 4500k DDM hids Heads&fogs, llumar ATR tint 30/15, Grey 10in stripes, led strips in footwell, clear corners w/switchback leds and smoked rear sidemarkers, HVAC and steering leds changed from green to cool white!
Current setup:
Engine: 2003 GT 4.6 n/a Trans: T3650 Mods (performance only):4.30's, K&N CAI, BBK UDPs, 91 Octane tune Power (not sure): 230whp ![]() Near Future setup: Engine: Same Trans: Same Mods (performance only):4.30's, K&N CAI, BBK UDPs, Zex 100 shot Nitrous, Full exhaust, Hi-tech cams ![]() Power (Goal): +300whp Faaaaar Future setup: Engine: ModMax 5.0 Stroker Trans: Basically Same (Aluminum driveshaft, Centerforce Clutch, lightweight flywheel) Mods : Procharger or Vortech SC, Ported PI 2v Heads, High flow Fuel pumps, maybe go 150 shots, maybe that's it Power (Goal): ~500whp (I will be very happy with that! )
Dark Shadow Gray 1 mod or 2 ![]() Thanks to Sarah for the Sig!! ![]() http://www.moddedmustangs.com/forums...-member-35708/ MM DSG Crew Member#3 |
Threads Similar to: What's your current HP and what are your HP Goals?
| Your 2.3 Goals | MSO | 2.3 Mustangs | 67 | September 20th, 2010 11:20 PM |
| What were your goals for your car? | normajean | The Clubhouse | 44 | September 2nd, 2010 09:14 PM |
| what are your goals for 09? | JonnyB | 5.0 Mustangs | 59 | March 18th, 2009 03:54 AM |
| Are these HP goals possible? | unlicensed to drive | 2005 - 2010 | 184 | February 24th, 2009 10:49 PM |
| I reached one of my goals | whitemustang02 | The Clubhouse | 111 | March 18th, 2008 08:58 PM |
