Look Ma! My First Post!
TURN SIGNALS STOPPED WORKING!! HELP!!
HELP!! MY TURN SIGNALS STOPPED WORKING IN MY 96 COBRA. WHERE IS THE TURN SIGNAL FLASHER LOCATED? ANY OTHER SUGGESTIONS AS TO WHY?
unstoppable @ speed of light
Did you check the bulbs yet?
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
Check the bulbs. Then check power to them. Then check youre Multi function switch. Its problably time for a new one. ( the lever you turn fopr directionals )
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
your headlight fluid is probably dirty
2001MustangGTCoupeYelloww/SatinBlack*3.73Gears AuburnLSDBBKColdAirIntakeBBKCaster/CamberPlates EibachMACCatbackMACO/RHpipeSportlineSprings SteedaTimingAdjusterSteedaUpperADJ.ControlArms SteedaShocksSteedaShortThrowShifter SuperiorAxles |
rtfm
#6 | |
Re: TURN SIGNALS STOPPED WORKING!! HELP!!
If the lights do not come on, including your interior indicators, I would say your switch went bad.
314RWHP 343RWTQ NON PI HEADS 8 PSI P-1SC W 3CORE I/C 03 IRS, TREMEC 3550, JBA SHORTIE'S MM SUSPENSION, BORLA STINGERS BASSANI CATTED X |
By the way, welcome to MM. Check the bulbs, then change the flasher usually located on the fuse panel. Then I would look at the MFS because its probably not that old if you are on the mod forum.
Had the same problem with my 94, there is a relay under the dash on the drivers side towards the door. After giving it a good bump or two the signals magically worked. Worth a try
Threads Similar to: TURN SIGNALS STOPPED WORKING!! HELP!!
| Turn Signals Problem | ridebmxfbm | 5.0 Mustangs | 13 | September 5th, 2007 12:22 AM |
| Tach Stopped Working.. 87 Mustang GT | NoRegrets | 5.0 Mustangs | 2 | September 2nd, 2007 05:28 PM |
| Odometer Stopped Working | 1995svtcobra | 94-95 | 22 | July 16th, 2007 08:46 PM |
| My keyless entry stopped working! HELP! | alex892007 | Audio/Video | 4 | April 15th, 2007 03:49 AM |
| Turn Signals | todd5501 | General Tech | 4 | April 29th, 2006 09:29 PM |
