crank pulley
Old June 18th, 2007, 06:07 PM   #1
mikedoogen is on a distinguished road
crank pulley
how do you guys recommend gettin my crank pulley off. it keeps spinning while im turning the nut. HELP
Old June 18th, 2007, 06:33 PM   #2
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
I assume you're doing UDP's? when I did mine, I ran into the same problem. What I did was, I took a floor jack and put it under the crank pulley. i raised it and put just enough tension on the pulley to keep it from turning with the nut. worked like a charm. BTW, once the nut is off, there's a washer behind it. If it doesn't come off when the nut comes off, make sure you remove it before you try to take the pulley off with a puller. I had a brainfart and it almost went really bad lol.
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old June 19th, 2007, 06:55 PM   #3
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
If you have a manual tranny, just put it in gear.and pull the e-brake.
Old June 20th, 2007, 01:22 AM   #4
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
or just use an impact gun
2004 GT Boosted by Vortech
Threads Similar to: crank pulley
98 crank pulley question 98mustang V6 Mustangs 3 August 16th, 2007 02:56 PM
crank pulley help mikedoogen 2005 - 2010 3 June 19th, 2007 01:17 PM
Crank pulley bolt? 88gtstang 5.0 Mustangs 3 March 9th, 2007 10:23 PM
HELP!! how do i remove the crank shaft pulley?? Onemanzu V6 Mustangs 12 December 30th, 2006 01:47 PM
Crank Pulley diameter 97TunedMustang V6 Mustangs 2 February 7th, 2006 07:26 PM
