foglight fuse
Old June 24th, 2007, 02:19 PM   #1
unblock is on a distinguished road
foglight fuse
my fog lights stoped working , i think its from the fuse , i checked the manual but didn't find any thing about fog light fuse ,
so does any any knows the location of the fuse so i can change i think its #11 but in the manual it says its for back up lamps ...
btw I have a 99 GT
Old June 25th, 2007, 08:10 AM   #2
ILUVSTANGS is on a distinguished road
it is located in the battery junction box along with power seat and power windows and your I/P.
it will be located next to the PCM PWR fuse or relay
good luck let us know if this helped
later
Old June 25th, 2007, 11:24 AM   #3
i know that it located in the fuse box under the steering wheel but i wanna know which fuse its :s
Old June 25th, 2007, 03:31 PM   #4
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
I think it should say in the owner's manual which fuse it is.. Otherwise you could go buy a haynes manaul for your car.
Old June 25th, 2007, 04:11 PM   #5
i have it but it doens't say where are the fogs lights fues
Old June 26th, 2007, 08:20 AM   #6
first off like alldata site states it's in the "battery junction box"
once you find that "box" (hint: under the hood) you will find the fog lamps relay......its the last relay next to the starter relay on the top row far right hand side...
switch it with another relay with the same numbers printed on the top and see if its the relay.....on that same row to the far left the last relay is a fog lamps cut out relay also check that one..
the only other thing it says is for fog. drl (daylight running lamps)..
if you still think it's a fuse then make it easy on us and either us a test light to find the blown fuse or pull each one out and check them....one at a time that is...good luck..oh and the relay part # is foaz14no89a about $8
later
Threads Similar to: foglight fuse
foglight help (v6) stanged out V6 Mustangs 8 September 27th, 2007 03:03 AM
Fuse box and IAC MnrlGry01gt 99-04 7 April 20th, 2007 03:02 PM
Foglight problem Cricket Audio/Video 2 February 13th, 2007 11:44 AM
fuse box help.....anyone? Bossman 2005 - 2010 5 February 8th, 2007 04:41 PM
Foglight Wiring '97 GT Rodan1 V6 Mustangs 1 January 1st, 2007 10:14 PM
