Hood won't pop???
It seems like everytime i go to pop open my hood on my 98 gt its like it is stuck... it usually takes me like 20 pulls on the handle before it will open or i have to have someone push down on the hood as i pull the handle... what do i need to adjust to make it work... its kinda embarassing sometimes lol...
maybe the little springs? I think those are what apply pressure to it so when it is released it pops up..
![]() 2004 GT Boosted by Vortech |
IBEATU
06 GT, 98 GT, & 93 Notch
Mine is the opposite. My 98 doesnt ever want to close. I have to slam the piss out of it sometimes with my hand over the latch area pushing down. I'm just gonna say screw it and get some hood pins. You could do the same.
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
Proud American
Just spray the latch and everything with some lubercating spray! It worked for my dads 84 silverado!
My 97 was hard as hell to open. I would pull and pull and pull and nothing. Then finally it would give and it would open. I took the hood off one day to work on the engine and after I put it back on the problem went away.... something to try...
Achieving more N/A power!
The alignment of the hood might be off. Check the rubber stoppers, sometimes adjusting the height helps.
Brendan '99 Mustang GT [ 318 rwhp N/A ] - SOLD ( )'04 F150 XLT SuperCab
Threads Similar to: Hood won't pop???
| GT Hood Scoop on stock v6 hood. | JSapit | Visual | 4 | July 13th, 2007 02:57 AM |
| where can i get this hood and hood scoop | thecloneranger | Visual | 4 | May 14th, 2007 01:29 PM |
| GT Hood on 6er | Cmpfreak88 | Visual | 12 | March 7th, 2007 02:56 PM |
| Cobra R Hood or Mach 1 or 2 Hood? Pick 1 of 4 hoods. | Chris02 | 99-04 | 16 | November 1st, 2006 09:46 AM |
