can i use a different ecm
my 98 mustang needs a different ecm can i use one out of a newer car? I have a sniper tuner to turn off the pats, thanks
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
Proud American
have you tried calling Colorado Mustang for a ECM for your 98? Give them a call!
www.coloradomustang.com BTW they have the worlds largest mustang only junk yard!
you should be able to disable the PATS system with a tuner, try contacting your tuner.
it will disable it but it still needs to comunicate with the system it just does not keep it from starting but the pats system still needs to work.
I'd disable it completely and be done with it. Just spend 99.99 and get a little GPS locator for your car and hide it underneath.
even disable it still has to be there in the computer to still work the ecm goes through a system of checks and even disabled it still checks to see if it is there it doesnt care about the programing but the circuitry needs to work.
