Cold Air Filter Serious problems
Aftermarket Air Filter for your cold air tube can be harmful for your engine. If you look at your filter you should see on the exterior side a steel brace, this goes the length of the filter and covers the seam, where the filter is joined together. If this steel brace is not on the exterior of the filter and you find it inside, replace the filter ASAP this steel brace will fail and being inside the filter it will travel through the intake and get logged in your throttle body causing damage to your TPS (throttle positioning sensor), your car will feel like its laking fuel and or running on 3 cylinders. If this part ends up getting to your engine you will have some serious damage. Filters sold within the last year solo or with an intake
This Brace is used to cover the joining seam of the filter and also stops filter from collapsing under loads.
07 Mustang GT Granatelli Motor Sports Show Vehicle 98 Mustang Cobra Convertible 06 Charger RT 05 RS1 Scion Custom Show Car 70 Fiat 500 Abarth Pinafarina Body rare car Nascar Vehicle New Project comming soon
wow sounds like thats pretty serious. I hope people notice this then.
"He that is good for making excuses is seldom good for anything else." "Who is wise? He that learns from every one. Who is powerful? He that governs his passions. Who is rich? He that is content. Who is that? Nobody." |
Y2K GT
13.3@103
just get a k/n filter to put on your CAI tube and your good.
Studies show that 92% of kids listen to rap. If you are one of the 8% who still listens to real music put this in your signature. |
If it makes it to your intake, it would surprise me. first the mass air has a screen over it, unless you removed it.
1986 Mustang GT t-top time piece! |
#5 | |
the fucks i gave today=0
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
reply On 05 /07 stangs the tube is long and the mass air is narrow and on a tube a thin bar has no problem, don't forget the suction it's just like a vacuum only stronger and the min size for a cold air is around 3 1/2''. Most braces are around 4 to 6 inch tall 1/2'' wide and 1/8'' thick and if it wasn't made for a strong stainless steel it possibly would have logged it self in the plainum or intake valve. And as far as filter goes it is a name brand filter.
2001 Mustang GT
8.9@78
![]() iTrader: 2 reviews
FOD...got to do those FOD checks...
Fire it up, burn it down.
reply On 05 /07 stangs the tube is long and mass air is narrow and in a tube a thin bar has no problem, don't forget the suction it's just like a vacuum only stronger and the min size for a cold air is around 3 1/2''. Most braces are around 4 to 6 inch tall 1/2'' wide and 1/8'' thick and if it wasn't made for a strong stainless steel it possibly would have logged it self in the plainum or intake valve. And as far as filter goes it is a name brand filter.
Is this spam ?
Its written like spam , reads like spam ,so it must be spam . My other question is,if the "steel" brace is on the outside of the filter ,how is it gonna get sucked through the paper and into the TB ? Your car makin 2000hp ?
Fryrice has left the building. |
on some filters manufactured and sold by big name companies, the brace was installed inside the filter
Well your post said exterior.
Anyways, that post doesn't special any type of brand or incidents.
This is pretty much a useless thread .
One Man Wolf Pack
:topicsucks
![]() ΜΟΛΩΝ ΛΑΒΕ
If it was a common problem, we would know by now.
We've all noted, when buying a filter, buy one that has had about 5 seconds of R&D into it, like any name brand, and this won't be an issue. |
#17 | |
faster than the stealth
but yeah he should say some names |
#18 | ||
"If you look at your filter you should see on the exterior side a steel brace"
Threads Similar to: Cold Air Filter Serious problems
| Fender well cold air intake filter installation???? | GHEDEUP | 94-95 | 3 | October 13th, 2007 11:45 AM |
| Fender well cold air intake filter installation???? | GHEDEUP | 5.0 Mustangs | 8 | October 12th, 2007 12:03 AM |
| air filter | CBSTANG | 99-04 | 9 | August 17th, 2007 03:03 PM |
| Cold starting problems | RyanGT | 99-04 | 7 | January 18th, 2007 05:27 AM |
| K&N Air Filter | jerb43 | 96-98 | 5 | January 3rd, 2007 08:14 AM |
