347 stroker
I own a 1998 Mustang. I am looking to buy a 347 stroker for my car. How much horsepower increase do I get and where can I buy one so that it will fit my car thanks.
need a cradle and everything else to do a 5.0 swap use the search button youll find it all
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
you can get everything you need from a 94-95 mustang...like he said...search button.. and the horsepower increase greatly depends on the motor. There are way too many 347 crate motors for you to ask that question. How much hp depends on how fat your wallet is..
Would this get me my horsepower increase
ESP-B14400020
$2,276.39 Estimated Ship Date: 8/21/07 Overview Application Warranty Show All Brand: Eagle Specialty Products Product Line: Eagle Competition Rotating Assemblies Part Type: Engine Rotating Kits Actual Engine CID: 285 Engine Stroke (in): 3.554 in. Pistons Included: Yes Piston Rings Included: Yes Piston and Ring Oversize (in): 0.020 in. Piston Material: Forged aluminum Piston Style: Flat top, with two valve reliefs Piston Head Volume (cc): +17.00cc Wrist Pin Style: Floating Piston Ring Facing Material: Plasmamoly Crankshaft Included: Yes Crankshaft Material: Forged 4340 steel Rear Main Seal Style: 1-piece Balanced: Yes Engine Balance: Internal Connecting Rods Included: Yes Connecting Rod Material: Forged 4340 steel Connecting Rod Beam Style: H-beam Rod Bearings Included: Yes Rod Bearing Undersize (in): Stock Rod Bearing Undersize (mm): Stock Main Bearings Included: Yes Main Bearing Undersize (in): Stock Main Bearing Undersize (mm): Stock Cam Bearings Included: No Gaskets Included: No Oil Pump Included: No Camshaft Included: No Lifters Included: No Timing Chain and Gears Included: No Plastigage Included: No Assembly Lubricant Included: No Quantity: Sold as a kit. ROTATING ASSEMBLY 4.6 * Check to make sure this part fits your application Quality assemblies from a name you can trust. Eagle competition rotating assemblies consist of name-brand quality components for a wide range of applications at an affordable price. Depending upon your application, these kits may feature a crankshaft, pistons, piston rings, rod and main bearings, and connecting rods, and balanced assemblies are also available Anybody know if this is a good idea for 2276.00 Give me your opinions/ thanks |
Threads Similar to: 347 stroker
| Stroker Kit 101 | scxc15 | V6 Mustangs | 5 | November 4th, 2007 12:46 PM |
| To Stroker or Not to Stroker? That is the Question! | 87StangLX | General Tech | 13 | October 20th, 2007 10:46 AM |
| 347 stroker | mustang_s | 96-98 | 2 | August 7th, 2007 10:57 AM |
| 347 stroker | 2007calispecial | 5.0 Mustangs | 8 | July 31st, 2007 07:55 PM |
| 331 stroker | ballzout | 5.0 Mustangs | 8 | July 20th, 2007 04:59 PM |
