96 GT/M8 Swap problems. - Forums at Modded Mustangs
post #1 of 5 Old July 20th, 2013, 10:25 AM Thread Starter
96-GT_Josh's Avatar
Ok, so lately My car had been having a bunch of random problems. Hesitates randomly, pops and gurgles while under constant 1/4-1/2 throttle. Horrible Gas Mileage, on side streets get maybe 5-8 mpg, hwy gets 14-18mpg. Dont ask cause IDK. I can fill up and drive 6 miles to the hwy and burn 1/4 tank. Then drive 50 miles on the hwy and burn another 1/4 tank. 8 CELs.
Some of the CELs
Coolant Temp not sufficient?
Cylinder misfire detected in Cyl #2 (how I dont have knock sensors?)
Engine RPM-Limiter reached/exceeded (I dont drive hard or go past the 7k RPM limiter)
OBDS11 Lack of Ho2 Sensor circuit
OBDS11 system indicates lean
OBDS11 system indicates rich
P1000 (never goes away: EGR and rear o2s turned off in tune)
And a couple more. I'm a state away from my car now but as soon as I get home tomorrow I'll get the code numbers and post em up.
It just seems like every time I fix something, it will throw another code.
Like I replaced both o2's and now its saying sensor 1 is bad. IDK if that has anything to do with the LT's and them being farther downstream. But I dont have the extension wires. My harness had enough slack in it to reach and plug in w/o strain.
96-GT_JOSH
I'D RATHER PUSH MY FORD THAN DRIVE YOUR CHEVY
MM COBRA CLUB #124
96-GT_Josh is offline
post #2 of 5 Old July 20th, 2013, 07:47 PM
Some of the CELs
Well, coolant temp and 02 sensor issues can definitely cause all of the symptoms. I would start with the ECT. When you did the M8 swap, did you be sure to use both coolant sensors from the GT? I had to get the crossover pipe from a 95 Mark VIII in order to get the two bungs for the sensors.
1997 Cobra.
JC316 is offline
post #3 of 5 Old July 21st, 2013, 05:05 PM Thread Starter
96-GT_Josh's Avatar
Yes I have both sensors in. The swap has been running fine for almost 2 years and since I put my clutch in all these issues appear.
The codes to be exact are.....
P0135: o2 heater circuit S1B1
P1131: Lack of H02S11 Switches Sensor Indicates Lean [see P2195]
P1000: OBD System Readiness Test Not Complete
And I just reset it. If I drive it for a couple days the
P1130: System Indicates Rich will appear as well as the lean code
And I forget the other code #'s but one is rpm/speed limiter reached/exceeded, engine coolant temp not sufficient for performance or something like that, cylinder #2 missfire detected (I don't have knock sensors so IDC how its getting that), and there is maybe 2 more, I forget what they are. I will drive more and update when they reappear.
Both new o2s and ECT sensors. I do have a 180° thermostat on my toolbox to install, maybe that might fix something but Idk.
96-GT_JOSH
MM COBRA CLUB #124
post #4 of 5 Old July 21st, 2013, 06:01 PM
It has some complex system of detection for the cylinder misfires. The RPM limit reached and misfires could be the crankshaft position sensor acting up. The 02 sensor issues can be causing the rich and lean codes. You need to inspect those and see whats up.
1997 Cobra.
JC316 is offline
post #5 of 5 Old July 22nd, 2013, 01:20 AM Thread Starter
96-GT_Josh's Avatar
Any input on how I would go about checking them? I might revert back to the stock tune but keep the rear o2s and egr off and see what happens.
The same time I put the clutch and few in I also installed bamas performance tu e. Maybe some things up with that as well.
96-GT_JOSH
MM COBRA CLUB #124
Human Verification
You may not post new threads
You may not post replies
