fuel drowning in the upper rpms
Old August 14th, 2007, 12:02 AM   #1
blakeasaurusrex is on a distinguished road
well, i got kind of a flat spot around 70 or well, 3rd gear.. the car falls on its face hard and the a/f goes down to around 10.8-11.5 - 1st and 2nd are great and hover in the mid 13's to 14s.
i've tried tuning with my sniper to lean it out in the mid and upper rpm ranges yet its not working, nor does when i try to adjust the idle speed using it.
anyway anyone know if anything else could be wrong as to why i'm getting too much fuel ?
1998 Mustang GT - Slow
Old August 14th, 2007, 01:05 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
what mods do you have and what size injectors?
Old August 14th, 2007, 04:48 PM   #3
um.. stock 19lb injectors
upr (hot) air intake - pi intake manifold, h pipe no cats, crapmaster 40s, 75mm tb, c&l upper intake elbow, asp underdrive pulleys and obviously a sniper tuner.
Threads Similar to: fuel drowning in the upper rpms
Leaning out - upper rpms? blakeasaurusrex 96-98 4 July 3rd, 2007 12:58 PM
Ford C-6 rpms dr.gonzo! 5.0 Mustangs 7 June 9th, 2007 02:03 AM
HELP, Car shakes bad over 2,800 rpms YNOT 5.0 Mustangs 18 April 16th, 2007 06:38 PM
shifting rpms o3gtdgs 99-04 23 December 28th, 2006 11:55 AM
dropping rpms rocket 5.0 Mustangs 6 August 21st, 2006 09:46 PM
