ok 3:73's or 4:10
Old August 14th, 2007, 02:26 AM   #1
2006 mustang gt
dont know
Ataylor is on a distinguished road
ok 3:73's or 4:10
ok i want to know how bad my gas millage will be affected and how reliable these gears are and how much will my top end go down i got a 5 speed gt 06 with flows and hypertech programer and k&n cold air intake with hurst short throw shifter any help on mods and the best bang for the buck i need help thanks i dont know much about cars yet
Old August 14th, 2007, 04:44 AM   #2
Moderator
4:10's are the way to go for me. In city driving, your mpg will actually be slightly better during normal driving, as it's easier to get the car rolling with the steeper gear. Gears are a torque multiplier. The higher the number, the better off the line. Figure on losing around 400 rpm in 5th gear on the highway. If you have a tuner, you can disable the top speed governor, so top end won't be an issue anyway. How often are you going to go 150 mph?
Old August 14th, 2007, 03:27 PM   #3
2006 mustang gt
dont know
true well i got that programer and i up my rpms 500 already so if i put the gears in would that make it about break even lol like i said i dont know anything about cars i am trying to learn
Old August 14th, 2007, 03:30 PM   #4
Moderator
Well I think you are referring to the rev limiter in your first 3 gears you adjusted? That won't give you more power, but it will give you the ability to shift at a higher point, particularly if you are power shifting a manual car.
I raised mine as well. That way, I can stab the clutch at 6 grand instead of 5700 or so. This way, when the clutch re-engages, the rpm's are still up closer to where the max hp is.
Old August 14th, 2007, 03:43 PM   #5
2006 mustang gt
dont know
yeah that is what i done so do u think those bolt on throttle body spacers are worth anything and also a summit underdrive pully kit are those worth buying
Old August 14th, 2007, 03:45 PM   #6
Moderator
The throttle body spacer is not worth much at all, no.
The underdrive pulley kit is worth about 10 horse. The only reason I wouldn't suggest an udp set is if you are running a massive stereo system (like me lol),and you do a lot of stop & go driving.
Old August 14th, 2007, 03:52 PM   #7
2006 mustang gt
dont know
ok yeah i do stop and go a lot and as far as the sound system i am debaeing bc i think my car would start to rattle to much with two 13.5 w7 which is in my tahoe so i think i will leave that out but i will put it on then i heard the throttle body spacer gains like 2 mpg that adds up lol
Old August 14th, 2007, 03:53 PM   #8
Moderator
I've not seen any data where the spacer will give you 2mpg. Your tuner & cold air intake will certainly give you some mpg, and the 4:10's will help a bit there as well, as long as you drive normally. lol
I have two 10" Alpine Type-X's in my car, and so far the rattles aren't bad.
Old August 14th, 2007, 04:12 PM   #9
2006 mustang gt
dont know
ok thanks well i guess for now that is what i am go n to do. do u know anywhere to get a spoiler one of those that sticks up a lil ways i think it was called a steda or somthing like that
Threads Similar to: ok 3:73's or 4:10
3.73's or 4.10's? silverstang05 2005 - 2010 10 August 28th, 2007 05:16 PM
3.73's or 4.10's TheBusher 99-04 9 August 4th, 2007 06:47 PM
3.73's or 3.55 what should i do?? Black Five 0h 5.0 Mustangs 8 July 8th, 2007 03:36 AM
3.73's 02steedagt 99-04 21 March 28th, 2007 11:00 PM
3.73's or 4.10's Redrider 94-95 18 March 11th, 2007 11:13 PM
