Coil gone bad on my 4.6 GT
Old August 21st, 2007, 05:11 PM   #1
zinc76's Avatar
zinc76 is on a distinguished road
What's up everybody unfortunatly my stang not running so well. My stang's an '01 GT intake and exhaust work only. She's hesitating and sputtering real bad during acceleration w/ no check engine light, she only has 50,000 miles and I do all the basic tune-ups pretty regularly. I have carmax warranty so I rather take her to a dealer for cost reasons All the feed back is greatly appreciated! I know these modular v8's are common for a coil-on-plug to go bad now and then and not throw a code.
Old August 21st, 2007, 05:22 PM   #2
Moderator
Check out www.lethalperformance.com or www.americanmuscle.com for an aftermarket coil setup.
Old August 21st, 2007, 06:09 PM   #3
11.21@123 -150 shot
orangeRcode is on a distinguished road
edit////So it's not throwing a code? hmmm, I would assume if you had a bad coil, it would throw a code. I will have to think this over some more. Below is my instructions for troubleshooting a bad coil.
If you are not ready to step up and buy 8 new coils, you can just replace the bad one. The easiest way to find it is to buy a new one and then just pull each coil off individually and see if it makes a difference. If it runs the same when you pull it off, it is probably bad. I have used this before and the procedure works very well and takes very little time to complete.
Old August 21st, 2007, 07:51 PM   #4
putermech's Avatar
1999 GT Black Coupe
putermech is on a distinguished road
Mine had same issue last month. Except I had a code that said #6 misfiring. Sure enough some water got under the coil. Coil is still good and some dielectric grease fix that problem, 15 minutes of idle to relearn and she was back to normal.
99GT 5sp
5 Speed w/ Trac-control
Old August 21st, 2007, 10:51 PM   #5
ujslost's Avatar
you should be getting a code. check for moisture under the coil.
Old August 24th, 2007, 03:38 AM   #6
MaD03's Avatar
2007 GT
MaD03 is on a distinguished road
i had the same problem. sputtering like crazy and not wanting to run WOT! i replaced the throttle position sensor, what i thought was a bad coil, fuel filter, and finally what it actually was, was a bad fuel pump! so what i suggest is that u replace the fuel filter, and double check all your coils for cracks etc.
but to be honest, i think its your fuel pump!
goodluck,
Rick
Old August 24th, 2007, 08:51 AM   #7
ujslost's Avatar
goodluck,
Rick
After reading what rick said and rereading the original post. Rick is probly right, if the car is good while its still kinda cool, then after its driven a while and warms up the fuel pump might be overheating and trying to shut off.
Old August 24th, 2007, 12:53 PM   #8
MaD03's Avatar
2007 GT
your exactly right! when my car was having this problem, it only did it when i ran for over 20 to 30 min! as soon as i went about 10 or so miles, cough, cough, sputter, sputter! and another thing, if u run your car low on fuel, the fuel pump will try to pump whats not there and eventually lock up, and or over heat causing it to completely stop working! i also had around the same mileage u had on your car, but that was my old 2000 GT. i drive a 03 now!
Goodluck,
Rick
"Your arms are to short to box with god"
07 Mustang GT
Hurst short throw
SLP Loudmouths
FRPP x-pipe
3:73's
BMR lower control arms/anti wheel hop
Threads Similar to: Coil gone bad on my 4.6 GT
coil Mustang RacR94 V6 Mustangs 11 November 3rd, 2007 12:41 AM
msd coil pack vs stock coil pack 97 cobra rubberdown Modular Mustangs 5 October 20th, 2007 12:50 AM
coil on dumps 2005 - 2010 0 August 13th, 2007 09:38 PM
2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec ozan169 2005 - 2010 4 February 7th, 2007 10:03 PM
coil pack to coil on plug conversion mustang_montana 96-98 6 July 24th, 2006 02:32 PM
