#21 |
Bearer of Bad News
I has mustang and legacy.
Slower than my Ruger.
A supercharger is going to be running all the time. Turbo kicks in at a set RPM range. If you're driving it on the streets and not hitting that set RPM range, it's not going to boost. Without that boost, you won't be burning as much gas. Therefore you'll retain SOME gas mileage. A supercharger will give you power throughout the band, whereas the the turbo has that lagtime before it boosts. However, you can get two different sized turbo (not to be confused with twin turbo). One smaller to spool up at lower RPMs and a larger one for higher rpms. In my opinion if you're going to do that, might as well supercharge it if you want to keep that load on your engine all the time.
Either way, a power adder will create more of a load on not only your engine, but everything else. You're going to want to beef up everything, such as your rear, put in subframe connections, rear shock brace, etc... If you plan on doing headers through exhaust, you're going to want to get a supercharger. That is unless you buy and install a custom rear-mounted turbo system. Then you can still have headers installed.
~MOD NUTSWINGER~ My Tongue Soothes Razorburn ![]() STOPSAYINGFAIL.COM EVERY FART IS A GAMBLE Just Think Of Me As A White Blood Cell.
#22 |
I would go turbo. Second choice would be a KB blower.
2003 GT-Ported heads, Comp cams, Bassani exhaust, full bolt on's, 3.73's. 1992 GT- TWS ported heads, Systemax intake, 3.55's, full exhaust, full bolt-on's. 2007 Cadillac Escalade ESV-Panty dropper. (Daily driver) |
Threads Similar to: Turbo or Supercharger....
| turbo, twin turbo, or supercharger? | mustangman87 | 5.0 Mustangs | 31 | March 6th, 2010 07:35 PM |
| Supercharger or Turbo? | Stangbro8994 | V6 Mustangs | 46 | May 20th, 2007 11:50 AM |
| turbo or supercharger | Danderson | V6 Mustangs | 39 | April 11th, 2007 11:26 PM |
| Supercharger, Twin Turbo, and Single Turbo | justinsstang | General Tech | 24 | March 7th, 2007 09:07 PM |
| Turbo or supercharger? | 98StangGT | 96-98 | 13 | June 24th, 2006 06:36 PM |
