OMG TOWELS IN OIL GALLEYS
I thought i had timing issues when doing my pi cams this week. I took the valve covers off today and the paper towels i put in the oil galleys were still there. Could this have caused the problems i was having? Harsh starts, no throttle response, fine until 2600rpms, could the oil galley holes being clogged have caused this?
steeda tri-ax, pypes catback & o/r x, BBK shorties, K&N cai, Full PI Swap, pro-m 80mm maf, 75mm tb and c&l plenum, steeda ud's, screamin demon cp's and ford racing 9mm wires, fox 4cyl front springs 260rwhp 290rwtq |
omg yes
Moderator
Yeah as soon as you start building rpm, and the engine is trying to build oil pressure, all kinds of shit could happen. The oil pressure sensor would be like "WTF?"
Smelly Fists, Socking Cocks
Millenium Falcon
Proud American
WOW
Sorry but LMMFAO! I have never done that before, but I did see once where a guy stuffed a shop rag in his intake when he was working on it and forgot and then it got sucked into the head and was stuck between a valve and valve seat ,he had to take the head off to remove that shop rag.
1986 Mustang GT t-top time piece! |
BTW, I just replace a head on an 05 Towncar with 20k miles on it, a piece of silicone glue from the factory found its way into an oil journal on one of the cam girdles and toasted the cam and head.
LOL
#10 | |
Re: OMG TOWELS IN OIL GALLEYS
Fryrice has left the building. |
Moderator
When I was serving my apprenticeship, we hired this young guy just starting out. His very first job was an oil change on an old Ford station wagon with a 302 in it.
He got the filter changed, the oil drained, and was filling it with oil with the bulk oil gun. One of the mechanics noticed that the oil gun seemed to be pumping for a long time. He filled it with oil all right. Right to the top of the friggin valve covers practically. lol Fortunately the mechanic noticed before he tried to start the car, so we just drained it out and filled it properly.
dont fell bad man at least you did not hurt anything ,, i'll tell you a little story of my owm , while back i did a gear swap on my 99 cobra at the time, i got about 6 blocks from the house end relized i didn't put any gear lube in the diff. i let it cool off 10 mins. and made it back home! about 1 mile total. > i dunno what i was thinking?
Sheesh,one time I was changing out one of my tail lights and totally forgot to put blinker fluid in it.
Luckily I realized it before I left my driveway. But now that tail light doesn't work ,and its leaking. Strange........
how did you forget blinker fluid? my car wont even crank if its low. but I did install my muffler bearing backwards once, it sounded like I was running open headers!
#16 | |
Lol @ muffler bearing. Thats not as bad as me not priming my air bags after my cam swap.
one time i went over 10,000 miles without changing the air in my tires, suppose to do it every 5,000 miles and well it nearly cost me a set of tires and wheels. the old air corroded the wire in the tire and my valve stems.
#18 | |
changing the air,thats good. I think Im gonna start a thread like this....BRB.
IBEATU
06 GT, 98 GT, & 93 Notch
WOW!! Glad you caught it in time.
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
