Checking for a bad vavle?
Is there anything i can do to check for a bad valve or somthing in the head. I bolted down the wrong side camshaft in last time i tried the pi swap, turned the crank, ptv contact, put it back to tdc, through the old cam in, turned the crank, everything was fine. Would bolting down the wrong side cam in the head do internal damage? I never tried turning the car on only turned the crank about a 1/4 turn if that and felt ptv. Would a compression check for all eight cylinders tell me?
steeda tri-ax, pypes catback & o/r x, BBK shorties, K&N cai, Full PI Swap, pro-m 80mm maf, 75mm tb and c&l plenum, steeda ud's, screamin demon cp's and ford racing 9mm wires, fox 4cyl front springs 260rwhp 290rwtq |
if you think you have bent a valve, do a compression check on each cylinder, if have one that has low compression that could indicate a bent valve.
also pull the valve covers, see if you have a valve that is not closing all the way.
1986 Mustang GT t-top time piece! |
Where are the valve covers on a 2001 cobra?
Engine Mods: slp loudmouth catback exhaust, pacesetter h-pipe, k & n cold air intake, jet chip Body and Interior Mods: Saleen front bumber, 18" chrome saleen rims, GT rear bumper and drop zone 2" lowering springs |
1997 Mustang GT
N/A
same place they are on any other car. on top of the heads on both sides of the intake manifold
Threads Similar to: Checking for a bad vavle?
| New guy, checking in. | 1/4-horse | 5.0 Mustangs | 9 | May 15th, 2012 05:02 PM |
| 02 Mustang GT Valve Rattle When Cold | ozbusurfer | 99-04 | 6 | December 12th, 2007 10:06 AM |
| Checking in from the ATL | ozaer | New Members Introductions | 22 | August 4th, 2007 06:48 PM |
| Just Checking In | Scrapdaddy SR. | New Members Introductions | 7 | May 16th, 2007 03:37 PM |
| FNG checking in... | Ronaele550R | New Members Introductions | 7 | January 8th, 2007 12:35 PM |
