Replacing coil packs on 02 gt
Old August 31st, 2007, 02:13 AM   #1
f4isvt is on a distinguished road
To replace the coil packs can you simply unbolt the two end bolts of the rail and set it to the side or is it necessary to unhook the rail and completely remove it?
Old August 31st, 2007, 09:32 AM   #2
beheivjer's Avatar
beheivjer is on a distinguished road
Some people say you can do it either way but its alot easier to just take the rail off
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old August 31st, 2007, 01:05 PM   #3
ok i figured by looking you could just move it to the side i dont feel like doing anymore than I have to since it isnt my car.
Old August 31st, 2007, 07:54 PM   #4
1999 Mustang
Invictus is on a distinguished road
you dont have to take the fuel rails off. just the little bolt holding the coil pack in itll flex to the side and pull right out.
Old September 1st, 2007, 09:46 PM   #5
ujslost's Avatar
IIRC use a 7mm or 8mm wrench on that bolt. dont make more work for yourself and take the fuel rail off
Old September 3rd, 2007, 09:07 PM   #6
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
As others have said, you do not have to remove the fuel rail--just unplug the connector and remove the single screw, the boots are more than flexible enough to get the coil packs out...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Threads Similar to: Replacing coil packs on 02 gt
Aftermarket coil packs!!! Grabber523 2005 - 2010 65 May 10th, 2010 03:37 PM
coil packs ricks01 Modular Mustangs 11 July 13th, 2008 12:40 PM
Ignition Coil Packs blackhavok 2005 - 2010 5 December 5th, 2007 03:56 PM
2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec ozan169 2005 - 2010 4 February 7th, 2007 09:03 PM
Help with coil packs 99modular 99-04 2 July 23rd, 2006 09:09 PM
