Compression test results
Old September 3rd, 2007, 12:55 PM   #1
97redgt is on a distinguished road
Cylinder#1 - 152(slow), #2 - 150(slow), #3 - 180, #4 - 170, #5 - 178, #6 - 170, #7 - 170(slow), #8 - 152(slow)
Car was warm, each time i cranked it over about 4 times, 5 for the slow ones. If i was to have a bad valve, wouldn't it be like 90 compression or something? I also found a good amount of oil on the spark plug threads on #'s 3 and 4, more on 4.
Car is also now throwing lean codes after i took it down the street to get gas. Do you guys think that with the new pi cams that my maf porting (removed middle shaft) which was done a couple months back could be throwing things out of wack? I also have a slight exhaust leak between midpipe and passenger manifold.
I was told that the computer on my car would re-adjust the timing itself if the timing was out of wack? True? Wouldn't the computer throw a camshaft sensor or somthing if the timing was off?
steeda tri-ax, pypes catback & o/r x, BBK shorties, K&N cai, Full PI Swap, pro-m 80mm maf, 75mm tb and c&l plenum, steeda ud's, screamin demon cp's and ford racing 9mm wires, fox 4cyl front springs
260rwhp 290rwtq
Old September 3rd, 2007, 01:08 PM   #2
ujslost's Avatar
Computer can only compensate timing so much. And it may or maynot throw a camshaft sensor code. You compression looks ok to me. As long as all cylinders are within 20% of each other. Tighten up your midpipe, or have it welded up.
Old September 3rd, 2007, 09:28 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
you cut the sample tube out of the maf??? if that is what you did and i read it right, that is your problem. i did that right after i got my mustang and it went to shit. i had to get a new maf housing for it. these cars have to have it to run correctly
Old September 3rd, 2007, 09:31 PM   #4
ujslost's Avatar
thats what Im wondering, if so, that car isnt gonna run right at all
Threads Similar to: Compression test results
200ci i6 Compression Test cgstarry Classic Mustangs 4 February 16th, 2011 06:46 PM
My results from FFW this weekend. 1SLO85 Pictures 16 September 12th, 2007 02:59 PM
White SMoke, ran compression test... 02Gt Stang 99-04 12 September 9th, 2007 04:41 AM
what would be the results? 2oo3c0bra 99-04 12 August 29th, 2007 04:54 AM
