2001 Saleen 281 #0101
Pulling stock shifter to fill with tranny fluid. Need tips
I am about to change my tranny fluid with mobile 1 sythentic atf fluid and fill it by pulling the stock shifter , but never done this before so need some tipe for all that have done this before. After I add 4 quarts of this stuff, should I seal if off with rtv silicone or am I ok since Im putting back to stock shifter? I know u need to seal it off with silicone if u are swaping out witha short shifter..
2003 Mach 1
12.7@107
![]() iTrader: 1 reviews
Why are you taking off the shifter to change tranny fluid? To change the fluid get underneath your car and look at your tranny there are two plugs the bottom one drains it and the top is where you put it in. If you do take the shifter off for some reason tho you will need to seal it with silicon, make sure you removed the old silicon seal with a razor blade or leaks could occur.
2003 Azure Blue Mach 1 5-Speed BBK LTs, o/r X-Pipe,FRPP 4.30 Gears, MGW Shifter, JLT Ram Air, AJE K-member, Eibach Sportline Springs, Moroso Wet Sump Street/Strip Oil Pan, Nitto 555Rs, Steeda Clutch Adjuster, SCT X-Cal 3, NGK TR55ix Plugs |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
just be sure the car is level when doing it. pull the top plug so it can drain and you know when it is full. pull the old gasket off and seal it up with silicone. i fill mine like that when i change my transmissions.
TT Bullitt
![]() iTrader: 2 reviews
+1. Filling through the shifter is convenient if you already have the shifter removed, otherside might as well just do it from under the car, although no reason you can't do it whichever way you want.
And yes, if you do remove the shifter you will need to seal it again with some sort of gasket sealant. I would recommend looking into CobraBob's stang shifter gaskets. The only reason I say that is they are cheap and if you use gasket sealer the shifter will be a ***** to remove next time, whereas with the gasket it will pop right off and you can resuse as many times as you want (assuming it doesn't get damaged) |
Are you sure you're not thinking of the older 5 speed trannys with the shifter on a plate mounted to the top of the transmission? These new remote mounted shifters are different. Like somebody said, there are 2 plugs, one to drain, one to fill.
Wait a minute, what year car are you talking about?
2006 GT 'Vert Screaming Yellow, Black leather 5 Spd MGW Shifter Brenspeed 93 Octane tune CORSA Performance Exhaust Retro-Solutions HIDs Last edited by Goldenpony; April 11th, 2009 at 08:13 PM. |
Threads Similar to: Pulling stock shifter to fill with tranny fluid. Need tips
| Tranny Fluid | armymike63b | 99-04 | 7 | November 12th, 2007 11:27 PM |
| tranny fluid | fsttang96 | 96-98 | 7 | October 27th, 2007 11:31 PM |
| tranny fluid | 96gtponyred | 96-98 | 4 | August 8th, 2007 05:49 PM |
| tranny fluid | Mustang RacR94 | V6 Mustangs | 1 | April 29th, 2007 11:18 PM |
| tranny fluid | terribleonexx88 | 5.0 Mustangs | 20 | November 24th, 2006 06:41 PM |
