Noise from rear - vid
Starting about a month ago (shortly after practiced some hard launches with the new clutch) I started getting some clicking/snapping sounds from the rear while taking off from a stop. The sounds aren't deep and there's no noise coming from the rear at highway speeds so I thought may be it was my rear U joint going bad. Today I'm checking it out and it looks like the U joint is fine. So I pop off the dif cover, lube looks fine with no broken pieces visable. Rocking the wheel back and forth I can pretty much reproduce the sound I'm hearing. What could this be? I have an idea.
http://www.cdrvideo.com/mustang/rear_noise.wmv
2002 Summer Beater |
After receiving suggestions from other Mustang boards it looks like a rebuilt is in order. I'll be replacing the two sets of gears, lock pin, S spring, C clips, and clutch packs. I'll be replacing the packs with the carbon fibre discs. These are the same that are in the 03-04 Cobra diffs. They offer better axle lock-up while operating and generate less heat. A nice upgrade.
![]() Woot, another Cobra part for the 6er.
Threads Similar to: Noise from rear - vid
| Rear Noise | Timmytattoos | General Tech | 1 | March 21st, 2008 06:51 PM |
| rear end noise | dirg5 | General Tech | 6 | July 18th, 2007 11:41 AM |
| noise in the rear | 4.6gtmarine | 99-04 | 2 | November 6th, 2006 08:15 PM |
| Rear End Noise. Help. | Invictus | 99-04 | 16 | August 15th, 2006 10:22 PM |
| Noise in rear end | OTreborO | 5.0 Mustangs | 3 | August 7th, 2006 05:47 PM |
