Manual fan override switch; Which wire to splice?
I just recently bought the ashtray rocker panel from uprproducts.com and I need some help finding which damn wire I need to cut/splice into... on one site iot says the #46 wire but how the hell do I find out which number a wire is? Any ideas people?
Billy Weston
I'm willing to bet your getting the #46 from a electrical diagram. Thats probably the pin number in the ECU pigtail. let me go find my haynes manual and i'll try to find it for you.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
That would be great! I need a haynes manual; probably a good idea eh?
you live in hampton? Ever see a green/teal colored lexus SC400 drivin by a younger black guy, (he delivers pizza for papa johns too)? Just askin because I went to school with him back when I lived in va
Billy Weston
Eh the haynes manual isn't helping me out to much. Of course the wiring for the fan isn't included. Then I also left my owners manual in my tool box at work so I can't locate the correct relay to tap into.
There are to ways to do it. One wire a new relay for the fan that ties into the current system. Or you need to tap into the high speed relays signal wire. I wish I could help you out on which relay it is but I am not going to be able to figure it out until tomorrow.
well if you find something else about it please post it, I've already went to advance and checked out a manual myself... didn't buy it yet and could find the pcm wiring diagram either so eh... oh well I can look for it tommorow.
Til then I need to finish up the wiring for my fuel cutoff switch and a pillar gauges |
nevermind man, found a new article that goes into much more detail. Thanks for looking for me though
Billy Weston
well when you get a chance post it
Taken From The Corral.net
Cooling the 4.6 Mustang with a Fan Switch PDF Print E-mail Written by §cott 96Çobra Tuesday, 22 June 1999 Unfortunately our Cobras and GTs DO run hot. There are a few ways to cool it. If it is a 96 Cobra you can try and get Ford to do the TSB cooling upgrade which will help, but the downside is that a bigger radiator (should you ever desire one) will no longer fit. Of course you could just drop in a Griffin, and be done with it. But should funds not be available …… read on. This mod was told to me by Ryan Hernandez (Purple Haze). I just decided to type it out! This modification can be done in about 20 minutes and costs next to nothing. When used, it will lower your operating temperature approximately 1 to 1.5 letters on the "Normal" gauge. All that is involved is to wire in a ground for the high-speed fan relay and switch it so that you can turn it on anytime you want, and leave it on if so desired! This mod I did last summer, and it WORKS LIKE A CHARM. THE MOD: Pull the passenger kick panel and locate the LIGHT-GREEN wire with the purple stripe. NOTE: There IS a dark-green one on the Cobra….(wrong one - it's a knock sensor wire). Anyway......once you have located this wire....which will be grouped with a bunch of other wires running from the EEC up the back of the fire-wall - hard to find, but it’s there......(very difficult to get to - Yoga helps).....tap into this wire (don't cut it in 2, just tap into it) and then solder it back up and tape it nicely. Then to test it quickly turn your key on to cycle, and touch the other end of the wire to the ground bolt (also under the kick panel). You will hear the fan turn on....YEY. Now, you are NOT done yet! Wire in a 1/2 amp in-line fuse holder with fuse (safety reasons - no other purpose) and then continue this wire to a switch and ground the other side of the switch. You are all set! Kenny Brown sells this package for quite a bit and they give you a switch that goes in the glove box. You could put it there if you want. I have a coupe, so I purchased an additional Fog-light switch and installed it in place of the coin holder. It's nice and neat and accessible. Grounding this particular wire simply closes the high-speed fan relay and turns on the fan! |
I'm actually re-wiring my fuel cutoff switch and my gauges and wiring this up right now..... and its 10:40 pm here... lmao
Threads Similar to: Manual fan override switch; Which wire to splice?
| Need help with Autometers blue wire to clutch switch | markush | 96-98 | 0 | September 8th, 2007 01:42 AM |
| Installing Zex window switch ! Tach wire help NEEDED | calpat1985 | 99-04 | 0 | May 8th, 2007 07:59 PM |
| Hanes Manual or Bolt On Manual | nHuman | 96-98 | 2 | February 21st, 2007 09:25 PM |
| How Much Is It To Switch To A Manual | jagstang89 | V6 Mustangs | 14 | October 30th, 2006 08:15 PM |
| manual fan switch | Rice Eater | 5.0 Mustangs | 0 | July 30th, 2006 01:03 PM |
