PINGING dammit
Old October 23rd, 2007, 08:36 PM   #1
jbsnake's Avatar
jbsnake is on a distinguished road
PINGING dammit
2001 cobra, bassani x w/cats, 4.10s, underdrive pulleys, CAI-- Bought about 6 months ago, last month or so has been feelin a little sluggish and pinging under acceleration. I'm guessing new plugs? maybe fuel system cleaning? any other ideas? Any suggestions on spark plugs??? THANKS!
Old October 23rd, 2007, 08:40 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
welcome to the forums.
run a higher octane gas first..
does it have a check engine light?
if so - pull the codes and let us know what the numbers are.
if not- just do regular service to it for it's mileage.
Old October 23rd, 2007, 11:37 PM   #3
93'_GT's Avatar
93'_GT is on a distinguished road
Try running SeaFoam.
Stock 5.0 Engine M/T Drag Radials
E.T.- 13.859
MPH-97.23
60 foot-1.853
Old October 24th, 2007, 02:19 AM   #4
ujslost's Avatar
Higher octane will raise the detonation point. If you are having detonation.
Old October 24th, 2007, 04:17 PM   #5
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
yeah dude, for sure try a higher octane. those cobras need to run on premium. in case you didn't know, pinging (detonation) is about the worst thing that can happen to your motor. DON"T get on the gas until you fix the problem.
Old October 24th, 2007, 06:33 PM   #6
ujslost's Avatar
Follow those directions to a T. Detonation is where you piston is actually just rattling around in the chamber. NOT GOOD!
Old October 25th, 2007, 12:27 AM   #7
jbsnake's Avatar
Thanks for the advice. I'm already running premium, as the car has always had. No CEL, no codes, pinging is usually only on hot days. Even then, not all the time, only when under load @ lower revs (like squeezing the gas in 3rd or 4th between 2-3 grand). Yeah so I could avoid this by downshifting every time I pass someone on the street, but that doesn't really solve the problem (and the cops take notice) So I'm guessing some new plugs and fuel system cleaner in the tank for starters-- again, any suggestions on plugs/fuel additives??
Old October 25th, 2007, 08:42 AM   #8
ujslost's Avatar
ngk or motorcraft plugs
IIRC there is a spark plug application sticky here on the forums
Old October 25th, 2007, 10:23 PM   #9
Fast98stang is on a distinguished road
you could have a bod knock sencor and check your EGR valve.
Old October 25th, 2007, 10:24 PM   #10
Threads Similar to: PINGING dammit
Dammit redfire Drick The Clubhouse 15 October 23rd, 2007 01:15 PM
Dammit NBA you broke MM Drick The Clubhouse 58 October 8th, 2007 05:22 PM
Dammit! I'm a pissed off guy today! TheStangStillShines The Clubhouse 23 August 20th, 2007 11:45 PM
dammit HMUSN The Clubhouse 19 July 30th, 2007 02:04 AM
