2003 Mach 1
12.7@107
![]() iTrader: 1 reviews
2v and 4v
Whats the diffrence between 2valve and 4valve engines. I mean besides the fact that one has two more valves. Like can you make a 2v engine a 4v somehow?
1998 Mustang GT
Need to hit the track
the 2v is SOHC and the 4v is DOHC. the 2v has two cams and 4v has 4. i'm guessing same bore and stroke, different heads. not sure what else, assuming same year of course
F-150 FX4
It's different heads. Consisting of valves, cams, intakes, exhausts, ect.
4v will make more power, better powerband, and will rev higher. |
2003 Mach 1
12.7@107
The 2v has one cam and the 4v has two cams actaully. So I could take the heads off a 2001 4v on a 2001 2v and then it would be a 4v, and add another cam? seems too simple lol....
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
#6 | |
my 4cyl geo storm is DOHC but only has two cams because it's a inline 4. make sense? a question i have though: are all DOHC cars 4v? my geo has 16 valves total = 4 valve per cyl... |
The 2v heads (SOHC) have 1 cam each and 2 valves per cylinder. There are 2 heads on the v8. DO some math and you come out with 2 cams, and 16 valves. The 4 heads (DOHC) have 2 cams each and 4 valves per cylinder. Totals out to 4 cams and 13 valves on those.
As for the heads themselves, the 4v heads have larger combustion chambers which allow for lower compression ratios, so generally they're a favorite with those interested in boostin. Unfortunately, the 4v heads are more complicated have have more parts, and are therefore,the aftermarket is more expensive on em. |
RLY SRS
#9 | |
2002 Chevrolet Impala
32 valves not 13 valves
