Funny Noise On Pass Side
Old November 21st, 2007, 06:58 PM   #1
sorrowfulkiller is on a distinguished road
So I started up my car today and I hear a really weird whining noise on the pass side, I was thinking it may have been the canister for the evap system since I know that my valve is a little screwed up right now... could it be that making the noise or does anyone else have any ideas?
It sounds like it's coming from either underneath the dash on the pass side or in the fender
Old November 21st, 2007, 07:37 PM   #2
96GtGoodz's Avatar
96 Mustang GT 5spd Vert.
Not sure need to go to a track
96GtGoodz is on a distinguished road
what kind of noise is it?
Old November 21st, 2007, 07:37 PM   #3
96GtGoodz's Avatar
and does it only happen at idle or when you move need details
Old November 21st, 2007, 08:02 PM   #4
mostly at idle or low rpm
Old November 21st, 2007, 08:29 PM   #5
96GtGoodz's Avatar
lol and what kind of sound rattling kinda?
Old November 21st, 2007, 08:54 PM   #6
No, a whining noise like a supercharger almost except not as high pitched
Old November 21st, 2007, 08:59 PM   #7
96GtGoodz's Avatar
hmmmmm is it constant like a supercharger or does it quickly cut in and out (like very quickly)
Old November 21st, 2007, 09:29 PM   #8
Cuts in and out somewhat... sometimes it stays on longer than other times
Old November 22nd, 2007, 12:58 PM   #9
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
a pulley maybe?
Old November 22nd, 2007, 01:42 PM   #10
Originally Posted by StangAddiction View Post
a pulley maybe?
No way, its coming from like underneath the pass side dash or in the fender not in the engine bay
Old November 22nd, 2007, 05:14 PM   #11
96GtGoodz's Avatar
i would also say definately the pulley i had the same thing i thought it was in the glove in the wheel in the fender and then i was told the idler pulley i looked under the hood and that was it i said no way it wasnt in the engine BUT IT WAS NEVER SAY NO WAY it could be
Old November 22nd, 2007, 07:06 PM   #12
im a firm believer that it's a pulley...Theres nothing in the dash that would be moving to make a noise like that. Im thinking its a pulley. At higher rpms, the pulley wont make much noise because its probably spinning much too fast but at lower rpms it may have a slight wobble from being loose. You could try tightening the bolts on your pulleys and seeing if that helps any.
Old November 22nd, 2007, 07:41 PM   #13
Proud American
MustangMatt96GT's Avatar
Cold air intake?
somedays i can hear mine like a supercharger and others i can even hear it.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old November 22nd, 2007, 08:10 PM   #14
96GtGoodz's Avatar
na matt i dont think its the CAI i firmly believe as well its the pulley that went out for me its the same symptoms
Old November 23rd, 2007, 09:25 AM   #15
My cold air and plenum together make a whistle noise at part throttle and when i let off the gas after full throttle but not at idle...It doesnt make a whining noise, but distinctly whistles some...
Old November 23rd, 2007, 01:22 PM   #16
Nate's4.6 is on a distinguished road
Also check the starter, that also sits on the passenger side right near the foot area. It could be "free" spinning after you start the car and could be on its way out.
Just a thought.
www.fquick.com/Nates4.6
Old November 23rd, 2007, 10:59 PM   #17
Just a thought.
That's a thought... I was wondering about that because it is starting to take a bit longer to turn on the car... if that is the case does anyone know offhand how much they cost? not worried about install I could do it myself.
Old November 23rd, 2007, 11:00 PM   #18
Coud be a pulley too... although I haven't heard it in the past couple days so idk yet...
Old November 24th, 2007, 01:53 AM   #19
96GtGoodz's Avatar
well my pulley is also bad its the idler we have the same problem i havent heard it in a few days and then i heard it from what your saying its the same shit pop the hood start the car and i will atach a pick of which it would be its the idler pulley
Old November 24th, 2007, 08:23 AM   #20
If it is the starter they around around $125 after you give them your core.
You also do not have to use a factory part if that is the case.
Threads Similar to: Funny Noise On Pass Side
pass side header stud/bolt sorrowfulkiller 96-98 17 November 8th, 2007 01:37 PM
Funny noise and jerking... TheBusher 99-04 9 October 31st, 2007 07:35 PM
Great...clunk in the rear pass. side twok3gt 99-04 2 October 14th, 2007 03:53 PM
Funny squeeky noise? sorrowfulkiller 96-98 5 October 8th, 2007 11:21 PM
Funny noise shadow98gt Modular Mustangs 4 April 27th, 2007 03:56 PM
