Discussing Keyless Entry Remote in the Modular Mustangs Forum. hey guys i need to program another keyless entry and the directions make no sense ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
96 Mustang GT 5spd Vert.
Not sure need to go to a track
hey guys i need to program another keyless entry and the directions make no sense can anyone please help me i dont want to have to go over to ford dont have time unless i absolutely have to
Deep Forest Green FTW!!!! ![]() Spending all my money on it ^ Make sure to leave rep for helpful posts ![]() |
1999 GT Black Coupe
For your 96'
99-04 are different. To program (or reprogram) keyless entry remote transmitter into the remote keyless entry module, perform the following steps: 1. Turn ignition switch to RUN or ACC position and momentarily short the two terminals of the Program Connector (two-pin connector next to the remote keyless entry module. Remove LH luggage compartment trim panel to reach the connector). Both doors should lock and then unlock. Remove shorting pin. 2. Press any button on keyless entry remote transmitter. All front doors should lock and then unlock to verify that keyless entry remote transmitter has been programmed. 3. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter). 4. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to a maximum of four keyless entry remote transmitters). 5. Turn ignition switch OFF. Both doors should lock and then unlock. 6. Check operation.
#33243 5 Speed w/ Trac-control Last edited by putermech : December 11th, 2007 at 03:24 PM. |
Threads Similar to: Keyless Entry Remote
| Keyless Entry Remote | 96GtGoodz | 96-98 | 27 | April 29th, 2008 05:19 PM |
| Keyless entry | 00GTstang | 99-04 | 24 | September 10th, 2007 09:05 PM |
| Keyless entry and more | trueballerisme | Electronics | 11 | December 24th, 2006 01:05 AM |
| Remote Keyless Entry Ford Expedition | ALLENY | All Other Vehicles | 2 | December 9th, 2006 10:21 PM |
| Car Keyless Entry | Dennis-96GT | Electronics | 15 | November 10th, 2006 09:34 PM |
