98 GT Won't Start... Theft Issue Maybe?
Old December 15th, 2007, 01:45 PM   #1
Blue98GT is on a distinguished road
So a week and a half ago i completely drained the battery in my mustang and then i got hit with a week and a halfs worth of snow and ice so jus yesterday i finally went out got a new battery put it in and everything has power now. When i go to start it the starter sounds fine everything goes as normal except it jus won't fire up. And i can't rember if my theft light is suppose to be flashing or not... Would the theft light be the issue if so how do i fix it. Also it has never has issues starting before until now. BTW yes it has plenty of gas and it is like mid 20 degrees outside. Thankx any advice is helpful im on college break and can't get home!!! lol
Old December 15th, 2007, 03:19 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
is the fuel pump working? the ses light will come on when the anti theft kicks. i cant remember if the theft light will come on. i broke my key, about a month ago. i just went and got a new key thursday, my car would not start because i did break my key.
Old December 15th, 2007, 04:11 PM   #3
98 Mustang GT
12.85
Darrin is on a distinguished road
That blinking light means trouble for you. It means that the system is keeping the car from starting for some reason. Do you have another key for the car? If so then I would try that one to see what happens.
Darrin
Old December 15th, 2007, 04:14 PM   #4
06GT4RAD's Avatar
2006 Mustang GT
06GT4RAD will become famous soon enough
Yep sounds like the theft system has been activated and is not recognizing the key. Sorry but the only way to fix that is to take it to the dealer and have them reprogram it.
Richard
2006 Mustang GT-Borla Stingers, MGW Billet Interior & Underhood, Eibach Pro Kit w/Tokico D-Specs, Steeda Sway Bars, CHE Suspenson Upgrades, BBR Billet Control Arms, Foose 20" Nitrous, BFG g-Force KDWII
Old December 15th, 2007, 04:27 PM   #5
Unfortuneatly i only have one key for the car and i found the fuel pump switch and it appears to be engaged so i don't think thats the problem also i have an sct xcal2 tuner and the car won't even recognize the tuner when i plug it in.... it won't even give the tuner power to turn on... so i guess ill jus have it towed to ford and have them fix it... if there are any other suggestions please let me know... thx
Old December 15th, 2007, 04:29 PM   #6
dansgt's Avatar
03 gt, 95 740i, 96 disco
dansgt has a spectacular aura aboutdansgt has a spectacular aura about
ya when it flashes it means it has a problem. meaning you probably reset the computer in your car leaving it dead for so long so the system doesn't recognize the key since it wont have a key programed to it. you got to go to the dealer for that.
Old December 15th, 2007, 04:44 PM   #7
98 Mustang GT
12.85
If it won't power the Xcal from the obd2 port then I would start checking fuses and connections. That makes me want to think that the computer in the car isn't getting power.
Darrin
Old December 15th, 2007, 04:52 PM   #8
96GtGoodz's Avatar
96 Mustang GT 5spd Vert.
Not sure need to go to a track
96GtGoodz is on a distinguished road
dam
Deep Forest Green FTW!!!!
Spending all my money on it ^
Make sure to leave rep for helpful posts
Old December 17th, 2007, 12:03 AM   #9
Elder's Avatar
2001 Cobra
Elder will become famous soon enough
Send a message via AIM to Elder
What color was you factory key? tan or black. all you have to do to program it yourself is a series of turning the key to the on and off position then leaving in the on position for 15 seconds and then starting the color makes the big diff because they have diff chips.
2001 Cobra: Built D&D3650,MGW,BBK longtubes, Bielstein,H&R racesprings, 4.10's, Magnaflow, Nitto
97 cobra
-SOLD
Originally Posted by drgnracin72 View Post
if your not breaking shit, your not going fast enough
Old December 17th, 2007, 10:42 AM   #10
98 Mustang GT
12.85
On a 98 that won't work.
Darrin
Old December 17th, 2007, 10:31 PM   #11
Elder's Avatar
2001 Cobra
worked on my 97 but it had the key pre programed before i sync'd it to the car
97 cobra
-SOLD
Old December 17th, 2007, 10:35 PM   #12
s3c2n01 is on a distinguished road
mine did the same thing. i have a 98 the fuel pump fuse blew and the light flashed. check the fuel pump and fuse. its in the box under the hood. one of the little yellow ones.
4.6 2V PI HEADS,PI CAMS,COMP SPRINGS,PI INTAKE,03 COBRA CRANK,PISTONS,5140 S/F RODS, VORTECH S TRIM 6/9PSI 3.73 60 LBS INJECTORS,90 MM MAF, SCT CUSTOM TUNE.
Old December 19th, 2007, 09:50 AM   #13
98 Mustang GT
12.85
97 is PATS and the 98 Mustang is definitely PATS II. I have one and I work on these cars for a living.
Unfortunately you can't program for another key or reprogram 1 on a 98 yourself unless you have 2 working keys.
Here is a link that I found by googling that explains it a little.
Ford PATS
Darrin
Old December 21st, 2007, 03:43 AM   #14
dansgt's Avatar
i work at pepboys, someone just brought in a 98gt for a nostart diagnostic-which is about $100. i take the key, turn it, see it flashing and tell him to go to the dealer, key chip's bad. i as a mechanic get 1 hour labor for that, for figuring out why it wont start, in this case turning the key and looking. they didnt beleive me so i hooked up the scanner...it said not recieving code from transponder chip in key. i got 1 hour pay for 5 minutes work. its times like this flatrate kicks ass haha.
Old December 24th, 2007, 11:59 AM   #15
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
Yeah I would def. say check the fuse first. But still take it to the shop, because there's some reason that the fuse blew. They don't just blow for no apparent reason. Unfortunately, with computers, theres not much the shade tree mechanic can do anymore
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old December 27th, 2007, 10:01 AM   #16
ujslost's Avatar
your pats transponder is bad. take it to the dealership and spend the money to get it fixed right
Old December 27th, 2007, 03:44 PM   #17
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
Ford PATS
Darrin
+1...you need two keys...i've been down this road b4...luckily i had a spare..You have to have one to program the other...
When you get your new key get a second and program it as well so u have a spare..
Threads Similar to: 98 GT Won't Start... Theft Issue Maybe?
Active Anti-Theft oldernewbie 2005 - 2010 20 December 12th, 2007 02:58 PM
Theft Light comes on, but dont have an alarm on the car WTF Mooooose 96-98 6 May 13th, 2007 06:23 PM
theft light comes on 4point6GT 96-98 4 October 14th, 2006 11:17 PM
fixed my hot no start problem, now i have a new issue!!!! gixxer1 5.0 Mustangs 2 August 30th, 2006 09:16 PM
help-- flashing theft light General Tech 20 February 16th, 2006 11:21 PM
