Discussing Turbo 03 GT in the Modular Mustangs Forum. hey guys i was wondering what the cheapest way to go turbo would be on ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2003 Mustang GT
Turbo 03 GTi only need a small setup like 5-6psi something like 100+hp or around that. i jus dont know what all parts my car needs to be ready for a turbo and also where could i get a single turbo setup i cant find anything. |
1997 Mustang GT
The turbo kit is just as expensive as a supercharger kit. The problem is that, to fit the tubing for a turbo, you need to swap out your K member. This usually means converting your front end to coilover with a full tubular set up. So in the end, it costs you about $1000 in parts, more than the Supercharger would. If you want cheap power, do a supercharger. Instant boost and less hastle. Unless you really want the most efficient set up with the ability to go big (HP and Hellion base kits are both good to 700 hp). It is not worth the money to get a turbo kit. Its cool, but unless you can build the kit yourself, and cheap, its not worth it.
The price is comparable (sometimes cheaper)with most centrifugal systems if you built it yourself...
13.334 @ 106.57
I would say it would be pretty safe to do a S/C install, but i would have a professional help you out with installing a T/C
Accufab 75mm TB and Pleunm, JLT cai, Steeda Caster Chamber Plates, Eibach Sportline Springs, Tokico Shocks/Struts, FRPP Aluminum Driveshaft, FRPP 3.73's, Hooker LT's, Hooker O/R X, Pypes Violator Catback, SCT Xcal 2. 280rwhp |
2003 Mustang GT
There is more labor with a turbo.. What is your goal? if you plan to never make much over 400-450rwhp go with a supercharger. There are nice turn key kits for 3600 and will make 380ishrwhp. (MPH mongoose) most intercooled GT's at 10psi will make dam close to 400rwhp, at 12psi your looking at 425rwhp er so.. 10psi on a stock engine is about the most you'll want to run without running into problem after problem..
A stock bottom end is said to be able to hold 450ish rwhp on a every day basis.. there are cars making a lot more than this on stock engines, but they will not last.. Project Ice box in MM&FF made tons of power on a stock engine and they drove that car forever, but that was only by luck. I know of a local car that let go at 12psi.. Its actually on its 3rd engine now.. Turbo cars are a little harder to tune too..
![]() P1SC, 3 core, bolt ons 395/435 |
96 Mustang GT 5spd Vert.
Not sure need to go to a track
turbo is cheaper not uncluding the little things ur gonna have to buy/fab/etc....
Deep Forest Green FTW!!!! ![]() Spending all my money on it ^ Make sure to leave rep for helpful posts ![]() |
Threads Similar to: Turbo 03 GT
| Turbo HorsePower Twin Turbo kit | dblindberg | 2005+ | 34 | June 17th, 2007 08:05 PM |
| Supercharger, Twin Turbo, and Single Turbo | justinsstang | Poweradders | 24 | March 7th, 2007 09:07 PM |
| Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 | Mellon | Videos | 10 | December 30th, 2006 10:05 AM |
| Turbo, Twin Turbo, Procharger, or Kennebell? | black94gt | 5.0 Mustangs | 19 | October 7th, 2006 10:41 AM |
| Super Charger vs Turbo/Twin Turbo: Pros and Cons of each | FireryDriver | 2005+ | 9 | September 17th, 2006 04:15 PM |
