Injectors Max Out
Old December 19th, 2007, 06:58 PM   #1
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
Injectors Max Out
So I have heard that 19lb injectors are tapped out at like 275 hp or something like that. Has anyone heard of this? I know that blown cars are running 36 and 42 lb. But if I am trying to get to 400 engine or 350 whp. Would I need to step up the injectos, what about the pump. My car is a 97 so I would think it would be a good idea to do anyway, but I just figured I would get some input. Id like to avoid swapping injectors if I could.
Old December 21st, 2007, 03:21 PM   #2
Trick Tuners's Avatar
KB'd GT
yes 19s are way too small for 350whp, even NA. If boosting you should go with 36s as a minimum for that power. You will probably need a pump as well. Fuel is one thing you dont want to mess with because running lean = boom and $$$$. Widebands are cheap motor insurance.
Old December 22nd, 2007, 11:24 AM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
I wouldnt advise trying to use the 19#'s for your goal. Are you going boosted? If so go straight to 42#'s even if you plan on low boost. This way it will still leave you room to grow if you want to up the boost.
If your gonna sta NA then 30 or 36#'s would do ya. It all depends on your plan.
Either way get a 255 pump and be done.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old December 22nd, 2007, 12:12 PM   #4
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
Here is an interesting read for you:
Robert's Nitrous Service | Dry Nitrous Tuning/Set-up, and some general spray info for all
This is to determine if your injectors can handle a dry shot, but some of the basics will still apply for what you need. The math equations here are very helpfull.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old December 22nd, 2007, 12:31 PM   #5
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
I was pushing over 300 RWHP N/A with stock fuel pump and injectors. After I changed to 30# and upgraded fuel pump, the pull was a lot smoother but I didn't pick up any power. It was just a little smoother mid range.
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Threads Similar to: Injectors Max Out
Injectors chickenbot 5.0 Mustangs 14 December 7th, 2007 01:22 AM
injectors white93pony 5.0 Mustangs 1 June 15th, 2007 05:08 PM
