Throwout Bearing Noise
Old December 20th, 2007, 05:19 PM   #1
1997 GT CONVERTIBLE
sharris is on a distinguished road
I wonder if anyone else has this symptom...97 GT convert, 5 speed. The throwout bearing is obviously going bad as it howls in cold weather. The odd noise comes when accelerating slowly in any gear. It sounds like a low grinding noise. If you tach it up and take off, there is no noise. Is this a thowout bearing symptom? There is no howl or noise at speed.
Regards
sharris in ala
Old December 20th, 2007, 05:21 PM   #2
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
my car did the same thing when the TB was bad........
sound like ur right on the nose dude
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old December 20th, 2007, 05:26 PM   #3
1997 GT CONVERTIBLE
Looks like I have a clutch job coming soon. great
sharris in ala
Old December 20th, 2007, 07:42 PM   #4
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
Your throw out bearing will not make noise if the clutch is not in. If you are in gear but the clutch pedal is pressed in, you will hear the throw out bearing. If you pull it out of gear and it stops or as soon as your foot is all the way off the clutch pedal and the moise stops. It is the Throw out Bearing. Otherwise it may be something else. A whining noise in the transmission either means it is grinding gears or the fluid is gone or bad. Take it to a good transmission guy and they will tell you. They won't charge you for taking for a spin.
Old December 21st, 2007, 09:59 AM   #5
1997 GT CONVERTIBLE
I checked the trans oil level and it is full. There is no whine from the trans, is sounds and feels smooth. Just a low growl/grind when pulling from a low speed.
I will drive it again tomorrow and investigate a little more.
Thanks
sharris in ala
Old December 24th, 2007, 12:01 PM   #6
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
My T.O bearing was, bad I had an entire new clutch put in last week. Mine made a really loud grinding sort of noise when i would hold down, or release the clutch, when it was in gear, there was no sound, whether i was accelerating or anything like that. It started to get so bad that i could hear it rattling when i was at stop lights tho.
Your pilot bearing could also probably be bad too. Mine was.
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old January 7th, 2008, 01:02 PM   #7
1997 GT CONVERTIBLE
I drove the car and noted the way I was using the clutch. When it was growling I had my foot resting on the clutch pedal. No noise when I dont touch the pedal. The noise is definitely the TB.
sharris
Old January 7th, 2008, 01:37 PM   #8
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
Fell bad but T/B is going south
Old January 7th, 2008, 09:06 PM   #9
AndrewA.'s Avatar
2001 Mustang GT
8.9@78
AndrewA. will become famous soon enough
I ahve an 01 and mine is really bad most of the time. It is sooo freakn annoying. Im just going to wait intill i can have enough money to get a alm. fly wheel with a good clutch kit.
Old January 7th, 2008, 10:17 PM   #10
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
Don't wait too long. Because supposedly, if the t.o goes, it can do damage to the front of your transmission when it goes out. Probably not a good thing to happen, so trying to minimize driving it, and get it replaced ASAP.
Cammed 2v
Old January 11th, 2008, 11:17 AM   #11
Casper98GT's Avatar
Depending on how bad the TB is. The bearing will make noise no matter what you do to the pedal. Free wheeling with the foot off the pedal is will make a chatterish noise, sometimes a squeel. When you push the pedal all the way down then you will also get a squeel and it will be louder. Its a very common problem on 96-98 mustangs
91 LX, 5spd.
Ex:Toyota/Ford tech
Old January 11th, 2008, 11:21 AM   #12
Casper98GT's Avatar
here give this a read.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old January 12th, 2008, 09:54 PM   #13
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
Yeah, that seems to be a common problem on these cars. Probably pretty expensive labor to put in a new T.O tho because you have to pull out the tranny.
Cammed 2v
Old January 25th, 2008, 08:57 PM   #14
marchant03gt is on a distinguished road
mine was messed up too. but i lucked out it happened like a few days before i did my tranny swap.
2003 GT | TKO-600 | Motive 3:90 | BBK O/R X | DynoMax Bullets | BBK CAI | Diablo Predator | Nitto Drag Radials | 260 RWHP | 290 RWT |
Old January 25th, 2008, 11:08 PM   #15
neverfastenough1's Avatar
Mine did the same thing when I bought it. Thought it was the TOB. Bought a Spec clutch kit to put in, but I changed the clutch quadrant and cable, and put an adjustable firewall adjuster in first. The noise went away, so I guess it was just out of adjustment. Been a month, still haven't changed the clutch and still no noise. Hopefully getting the clutch in this weekend but not looking good.
Old October 14th, 2010, 03:48 AM   #16
moneymo's Avatar
1991 Mustang Gt 5.0
moneymo is on a distinguished road
Mine makes a metal to metal grind when i slowly let off on the clutch. Then to make matters worse i tried to move it and the transmission locked on me. I know it cant be the clutch or pressure plate because they wouldn't lock up. Can anyone help me with this one? I just got a new tranny in but i wanna hear from you guys if its anything else besides gears being gone. If so i will put the new tranny without messing with the bell housing..lol
Threads Similar to: Throwout Bearing Noise
Throwout bearing has gone out Stagray 96-98 5 August 30th, 2007 10:13 PM
Tremec 3550 Throwout Bearing jtillery 5.0 Mustangs 3 June 27th, 2007 09:46 PM
Throwout going out??? Blackblurr_00GT 99-04 4 May 8th, 2007 10:21 PM
Throwout bearing mu5t4ng 96-98 2 January 16th, 2007 11:25 AM
throwout bearing q's Casper98GT 96-98 0 June 11th, 2006 09:49 PM
